Old 06-17-2022, 12:38 PM   #1
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
What is an LSA conversion worth?
Hey guys, I’m thinking about swapping over to a magnum 2650 and I’m trying to get an idea of how much my current LSA setup is worth. It’s a ported blower and snout with about 15k miles since new, and a 2.55 upper. It seems to me like none of the main stuff from the LSA is retained on the new magnum 2650’s so I think I could sell it as a pretty much full kit. I’d keep my rails/injectors, throttle body, and maybe the intake but I may upgrade the intake with the new blower. Let me know what you guys think. PFA
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 06-19-2022, 09:41 AM   #2
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
I bought a used LSA basically piece by piece, some new some used. In the end I spent between $5,000 to $6,000 (not including tune, or CAI). My guess is that someone would pay you in that range for a almost complete setup.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 06-19-2022, 11:23 AM   #3
Little Walter
Drives: ZL1
I would recommend holding on to it until you are for sure the 2650 is performing to your satisfaction, I've notice a lot of the Cadillac forum guys going back to the ported LSA.
Little Walter is offline   Reply With Quote
Old 06-30-2022, 12:10 AM   #4
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Off topic but your cai is that 4” or 5” carbon tubing?
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
