Old 06-29-2022, 12:57 PM   #1
ICUP
Drives: Chevy Camaro
Drawbacks using Ls9 heads?
Was originally going with TMS for my build, but their prices has skyrocketed. The shop I'm going through spec'd out the same thing just using Ls9 heads compared to M311 heads. Saves me about 3500-4K also.
Any drawbacks, or power will be the same output?
ICUP is offline   Reply With Quote
Old 06-30-2022, 11:29 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
In the ZR1 world, Ported LS9 heads are making the same power as aftermarket heads. For a ZR1, the only reason to go to an aftermarket head is for a 6 bolt set up.
I don't see any drawbacks.
For the record, I am running a set of AFR 260 heads ported by Tony Mamo. I wish I had known about the lack of power gains vs stock ported heads and kept the LS9 heads.
Old 07-05-2022, 07:14 PM   #3
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
The LS9 has a better material, but they flow less than a LS3 stock vs stock from what I've seen.But if you have them ported or CNC's.,then it's a difference story.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 07-05-2022, 10:10 PM   #4
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
For a boosted application, the LS9 has my vote. Port those babies and let 'er eat!!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-06-2022, 02:23 AM   #5
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD
I have a set of Katech CNC ported LS9 heads. I also have a new set of M311's and a set of PRC LS3 heads. Let me know if you need more info about any of these.
ZL1C7 is offline   Reply With Quote
Old 07-17-2022, 12:34 AM   #6
ICUP
I'm not planning on running huge power, but the shop I'm going through has used ls9 heads on some of their 1500hp builds.
Old 07-22-2022, 12:03 PM   #7
4SFED6.0
4SFED6.0's Avatar
Drives: 1991 Camaro
Im running a set of gmpp cnc'd ls9 heads and am very happy with them. With the ls9 block im able to take advantage of the 12mm head studs. The block used to be the same price as an ls3 but I believe its now been discontinued. Im sure there are comparable or better aftermarket heads out there but I wanted to keep it all ls9.
2011 SS Twin Turbo
Forged LS9/6L90E
Runs 9's
4SFED6.0 is offline   Reply With Quote
