Old 07-02-2022, 03:47 PM   #1
Judd_123
Drives: 2011 Camaro 2ss
L99 gpi ss3 install
Has anyone on here located or made a write up on the L99 Ss3 vvt cam install. I am going to be doing this in a few weeks when all the parts arrive. Also wondering on trans removal for converter install
Judd_123 is offline   Reply With Quote
Old 07-02-2022, 07:17 PM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
https://www.camaro5.com/forums/showthread.php?t=125123
Also one for converter install in the DIY area
joshnmn is offline   Reply With Quote
Old 07-03-2022, 05:48 PM   #3
Judd_123
Was looking more on the l99 based engine instead of the the ls3 one. As I will be running a vvt cam instead of the 3 bolt ls3 cam. So will change the lifters and afm delete valley cover as well as timing set and phase limiter. So was looking for something around those installs.
Old 07-04-2022, 05:25 PM   #4
Judd_123
Anyone??
Old 07-05-2022, 12:59 AM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
There is a video or at least there was one on GPI's website or maybe on youtube showing how to install the phaser limiter and I don't think that you have to remove the oil pump to change the cam but someone else will have that answer that. As far as everything else it's pretty straight forward the hardest thing that I can think of is the two front bolts under the oil pan that bolt into the timing cover are a pain.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 07-05-2022, 01:06 AM   #6
morepowerjoe
On second thought I'm sitting here thinking about it and it is a pretty big job. Are you a mechanic?
Old 07-05-2022, 10:25 PM   #7
Judd_123
I am not a mechanic in daily life. I am a machinist. I believe I can handle the the task at hand was just asking/looking for any info or tips for someone that has done it
Old 07-11-2022, 10:23 AM   #8
Scott S
Scott S
Drives: 2011 Camaro 2SS
Pull the motor as you need to get rid of the pressure relief in the oil pan and put in a LS2 oil pump.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 07-23-2022, 07:45 PM   #9
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
I did my L99, but converted it to a Ls3 setup. Step by step write up on here
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 07-23-2022, 07:47 PM   #10
gunchamp
gunchamp's Avatar
https://www.camaro5.com/forums/showthread.php?t=568830
