![]() Drives: 2015 SS Black/Black Join Date: Jun 2016
Cam price
What do you guys think is reasonable for a cam install and tune on ls3? Looking at a cam, push rods, trunnion upgrade, 3 bolt upgrade, springs, and supporting gaskets and bolts. Waiting on some other quotes but first one is 4500 with parts. BTR quoted me roughly 1200 for the same parts. Seems a little high for labor and tune.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Tri-County Camaro SWFL
1200 for parts AND labor?
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Check out GPI website. They have cam kits where you just go down and click what you want. I just did it with the parts you listed and it was 1300- without lifters. Add 500 for tune and $150/hr shop time. It would take me a full day. I'm sure shops can do it faster
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Are they insisting on pulling the heads for the swap?
figure $500ish for the tune and about $1500ish for the labor and then the price of the parts. Some shops have lost their minds since Covid. $4500 is a little high, but if a big shop like Redline, that is what you can expect. I did the swap in a weekend taking my time, but I did not do springs since it was a lower lift cam. My guy did the second one for around 2k with a retune, but most guys would be afraid of his shop as it's small, crowded and all the parking is filled with project cars.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#6 | |
#7 |
4500 is pretty reasonable for parts, labor and a tune. Remember you get what you pay for. Nearly anybody that has a sense of how an engine works can install a cam in this car. Its the tuning that you really need to worry about.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I definitely agree with you on this. You do get what you pay for. I think I paid around $4200 (parts and labor) for mine not including the tune. I would suggest going to a performance shop that can do a dyno tune afterwards instead of doing a mail order tune / email tune. Just make sure you find a place with a good tuner.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#9 |
Note, I provided the parts.
#10 |
Keeper of “THE list”
That is way into the stratosphere for a quote on a LS3. That’s even high on a L99. A LS3 cam swap should be $2,000-$2,500. Heck, my L99 cam swap only cost about $3,600 and they pulled the heads to replace the garbage AFM/DOD lifters. Look around at others shops and see what they’re charging. That quote sounds completely off the deep end high. Maybe they don’t do many cam swaps and if they’re going to, they’re going to make it worth their effort to them.
#11 |
I figure that otherwise be one hell of a deal!
#12 | |
#13 |
Just because you looked at a name brand shop, it doesn't mean they aren't trying to stick it to you. That price for a LS3 cam install is outrageous, IMO. Good luck and hopefully you get your cam in soon!
#14 |
Do you guys do the oil pump and ls2 style dampener at this time or is it not necessary yet. My goal with the car is to be in the 600-650 whp range.
