07-13-2022, 12:41 PM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
Flex Fuel Sensor Options & JMS Powermax
I’m finishing up my parts list for my build & was looking at picking up either the DSX flex fuel kit or the Lethal garage kit. Both use oem parts and look like great kits. Any advantage of one over the other? I kind of like how the Lethal hides the sensor behind the supercharger.
Second question. Would I benefit from running or will need to run the JMS Powermax? Might be a better question for the tuner. More than likely it will be tuned by Ted. I’ll be running CSP 2” headers with GESI gen II ultra cats, regular rotofab intake, Soler 91mm throttle body, awe catback, flex fuel, new plugs. Currently running the Soler throttle controller Thanks for any info Last edited by Cleancoupe; 07-13-2022 at 02:39 PM. |
07-13-2022, 02:14 PM | #2 |
Drives: '18 ZL1 1LE Join Date: May 2020
I've had zero issues out of my JMS setup that Ted tuned for me. If you're going flex fuel you will certainly need one or the other. I'm not familiar with the DSX aux system, but I did the install of my JMS and it's worked like a champ from day one.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
07-13-2022, 03:36 PM | #3 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Ted will probably recommend the DSX flex fuel kit along with the JMS voltage booster for low side fuel pressure stability. Zero issues on my setup as well, fuel pressures are fine, tested up to E60. (For the record, this is an SS, not a ZL1, so there's that.)
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
07-13-2022, 03:40 PM | #4 |
Drives: 2017 ZL1 Join Date: Jan 2017
I am a proponent of the JMS FuelMax, I have one installed and it does the job! No matter what your HP fuel requirements are it would never "hurt" to have one installed.
I haven't messed with flex fuel since it is not available in my area, surprised with your minor amounts of modding that the stock ZL1 fuel system can't handle a higher ethanol content fuel. I will follow and learn something
2017 Camaro ZL1 Coupe M6 (847whp Dynojet on 93)
07-13-2022, 04:39 PM | #5 | |
Drives: E92 BMW M3 Join Date: Oct 2012
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
07-13-2022, 05:25 PM | #6 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I'm still learning zl1's, I came from an ss. I believe you can run up to e50 or so with stock fuel system with booster and flex fuel on zl1. Might want to double check, but pretty sure
07-13-2022, 05:45 PM | #7 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
If you are not running aux. gauges, and you are not running straight E85, then I suggest considering the Advanced Fuel Dynamics Kit.... with Bluetooth and an APP to see your real-time blend.
https://www.advancedfueldynamics.com...olet~md_camaro
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
07-13-2022, 06:23 PM | #8 | |
07-13-2022, 06:24 PM | #9 |
I’m sure he will. I’m going to give him a call and get his thoughts. I’ll probably be running between 40-50% E based on what I’ve been reading
07-13-2022, 07:02 PM | #10 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Full e85 with JMS,BB HPFP, +30 injectors but I’m at Denver altitude (can run a little higher ethanol here).
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
