SoCal C5 Family Member
Ram Air Hood VS. Heat Extractor Hood
In my opnion, your hood is one of the main things that sets the look of your car apart from others.
As far as functional hoods go, what are your thoughts on keeping your under hood air cooler? |
JAWS
Drives: 2010 2SS Silver Ice Metallic Join Date: Aug 2009
No thoughts.
Dry ice! ;]
JAWS
Hello!
Ram air hoods are typically functional when they are tied to the intake system. Therefore your under hood temps would not affect the air going into the engine. The limitation with ram air is unless the car is moving...there is no air being "rammed" into the engine.
If it's just an open slot then I'd think it would move the air pretty good when moving but again, when sitting idle little if any. An extractor hood will release underhood heat thru the vents/outlets...again though, with the car sitting still there is little if any heat getting out as the pressure from a moving vehicle is what "pulls" the air thru the vents/outlets. Two different functions in my mind...but if you are worried about underhood temps, an extractor hood will pull the air out where as a ram air hood (if hooked to the intake system) would not. |
#6 |
Florida C5
Drives: 2010 Camaro 2SS Vortech L99 IOM Join Date: Jul 2009
Extractor 4 me, heat leaves wether I'm moving or not, but I'm movin!
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
#7 | |
![]() "Discovered by the Germans in 1904, they named it San Diego, which of course in German means a whale's ******." |
#8 |
![]() Drives: 2010 Join Date: Jul 2009
| NEW Ram Air hood Pictures by Rksport | henri26900 | Cosmetics and Lighting Modification Discussions | 164 | 04-08-2012 05:21 PM |
| RAM AIR MYTH OR TRUTH | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 06-18-2010 11:41 PM |
| ram air style hood? | tsg1391 | Cosmetics and Lighting Modification Discussions | 1 | 10-23-2008 04:43 PM |
