Old 07-24-2022, 12:02 AM   #1
Bubbafire88
Bubbafire88's Avatar
Drives: 2010 Camaro ss A6 "Chief"
New built transmission slipping
Hi y’all, I got my 6l80 built a few days ago and just got around to breaking it in and filling it up with fluids, currently the trans fluid is at the correct level it should be at but when I put it in drive or sport mode (without paddles) it slips out of gear with a little rev, but when I use the paddle shifters it stays in gear just fine.
TSP stage 2 cam | aFe cai | Speed Engineering Long tube 1 7/8 catless headers | Self Ported TB | Circle d 245mm 4400 stall | ZL1 NPP Cat-back exhaust | 3.91 gears | Full BMR suspension/bushings |VMS drag pack 17x10, 17x4| Granatelli Motorsports pro stock spoiler| Heritage Grille | Zl1 Addons front bumper conversion kit | Whole lotta weight reduction
Bubbafire88 is offline   Reply With Quote
Old 07-24-2022, 08:43 AM   #2
gtstorey
We’re the transmission adepts reset?
Old 07-24-2022, 05:05 PM   #3
Bubbafire88
Im not sure, ill ask my builder if he did that, it started happening on the transmission before I got it built, found out water got in making the fluid pink and burning everything up, before that everything was all good.
Old 07-24-2022, 05:20 PM   #4
gtstorey
Who installed the transmission after rebuild?
Old 07-28-2022, 11:16 AM   #5
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
I had a ZL1 back when they first started using the 10 speed that did the same thing when it was cold. Had the trans apart 2 times and didn't find anything. Finally convinced the product engineer to let me try a converter. That ended up fixing the car.....why I have no clue, but they took the old converter back to Detroit.
NOT A 45 is offline   Reply With Quote
Old 07-30-2022, 12:57 AM   #6
Bubbafire88
The converter is a brand new 4400 circle d single disk, i hope its not a converter issue
I installed it after the rebuild, triple checked everything, used reference photos etc.
Old 07-30-2022, 08:20 AM   #7
gtstorey
The transmission adepts have to be reset once the transmission is back in the car.
Old 08-05-2022, 08:46 PM   #8
Bubbafire88
Well took it to g-force motorsports down here in south Houston, they found a lot of metal in the trans pan and are taking the trans back out to disassemble it and find out what's wrong, they think the transmission wasn't built correctly, but we will find out soon enough
Old 08-06-2022, 10:07 AM   #9
NOT A 45
NOT A 45's Avatar
Without even looking at it I can tell you if there's metal debris in the pan, the front pump is destroyed for sure!
Old 08-06-2022, 10:14 AM   #10
gtstorey
Decent chance the torque converter failed.
