Old 08-01-2022, 09:23 PM   #1
ICUP
Drives: Chevy Camaro
Going full send
I've decided to go full send on this build since the engine will be out. Cheaper in the long run, and since the cars down, why not.
Engine 408/ls9 heads
ECS 2200R
Fore Triple pump
With me having the ecs 1500 right now, should I stick with the 8 rib or just go with the 10 rib upgrade? With upgrading to the 10 rib, will I needs a new ATI balance?
What upper pulley size?
Should I add in meth into the mix? Currently have flex setup.
ICUP is offline   Reply With Quote
Old 08-12-2022, 05:05 PM   #2
hillshooter
Drives: 2015 Camaro SS commemorative
this is 25% send if anything
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 08-19-2022, 07:18 PM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
This lmao. I guess everyone has a different opinion of full send.
But to help out stay away from ls9 heads unless you have them ported, there is an obstruction in the port that gets removed or just stick with the factory 821 heads to keep cost down as they're plenty for what you're doing
10 rib is a vast improvement and the blower should be on its own belt meaning you'll just need a 10 rib lower pulley
ttshovel is offline   Reply With Quote
