08-07-2022, 09:36 PM | #1 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Brembo ZL1 Front Rotors
Rotors SOLD!
$125 Plus Shipping to CONUS. Info and pictures below. Calipers SOLD. I have a front 6 piston Brembo setup for sale. I ran these on my '14 SS 1LE. I traded the car in late last year on a Gen6 SS 1LE. These are the C7 Corvette Grand Sport/ZO6 front calipers with the vented pistons, part #s 23242498/23242497. They were sandblasted and epoxy coated with the G2 epoxy system. I brushed it on and they are not perfectly smooth. They are not car show calipers. But if you are looking for a setup for the track, they will not discolor from the heat. They come with the pins, cross tie and bolt and pad bracket. New seals installed. The rotors are the Gen5 ZL1 2 piece Brembos, Brembo part #s 09A66513/09A66523 which cross to the GM Brembos, part #s 177-1145/177-1146. They are also used with some crazing (heat surface cracks) that develop from heavy track use. I ran these with Raybestos ST43 pads. Crazing is superficial until you can catch your fingernail on them and/or the cracks propagate to the edge of the rotor. Plenty of life in them. I also have a set of OE ZL1 Brembo/Ferodo HP 1000 pads for sale here on the forums. These pads are a compound match to the rear OE pad on any Camaro SS The following threads describe the install and additional parts required (ZL1 front brake hoses and lower heat shields). $800 plus shipping to continental US. PayPal only https://www.camaro5.com/forums/showt...piston+brembos https://www.camaro5.com/forums/showthread.php?t=348133
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
Last edited by cdb95z28; 11-22-2022 at 07:47 PM. Reason: ROTORS and Calipers Sold. |
08-08-2022, 08:37 PM | #2 |
Drives: 02 Camaro B4C Join Date: Nov 2016
PM sent
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
08-22-2022, 09:13 AM | #3 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
any interest in selling just the calipers? price?
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
08-23-2022, 12:05 AM | #4 |
No, I have interest on everything. Waiting on a local guy's decision.
09-28-2022, 08:34 AM | #5 |
Calipers SOLD
11-13-2022, 06:46 PM | #6 |
Rotors available for $125 Plus Shipping to continental US.
11-21-2022, 01:53 PM | #7 |
Price drop
11-22-2022, 07:47 PM | #8 |
Rotors sold!
