Old 08-08-2022, 01:39 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Blend Door AC Repair - Part Number
I’m about to repair the broken blend door AC issue but not sure which part number is needed for the motor that connects to the door.
I have the blend door and white connector piece. GM lists 2 different motors and I just need to know which one I need to order. The only one that people have referenced is a Dorman part number. I would rather get the GM one.
Thanks in advance.
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 08-08-2022, 01:51 PM   #2
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Thanks in advance.
My catalog is down but the a/c delco number is 15-74128
NOT A 45 is offline   Reply With Quote
Old 08-08-2022, 08:49 PM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Do you happen to have the Blend Door Part # Handy, I don't need one now but I think I want to have one on the parts shelf.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 08-09-2022, 12:28 AM   #4
dma05
dma05's Avatar
Thanks for the part number!!
The blend door part number is 1551251
Allen
2011 Camaro 2SS/RS
Old 08-09-2022, 08:08 AM   #5
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Added to database.
Heater Blend Door Database
0stones0 is offline   Reply With Quote
Old 08-09-2022, 08:35 AM   #6
gtstorey
I think the GM part # (as opposed to the AC-DELCO# above) for the door is 92215212.
Old 08-09-2022, 08:56 AM   #7
Joe.G
Joe.G's Avatar
Is there a Difference between AC/Delco and GM? I believe they are the same manufacture just different brand.
Old 08-09-2022, 09:27 AM   #8
NOT A 45
NOT A 45's Avatar
AC Delco is GM! Just as Ford brands their replacement parts with the Motorcraft name, GM brands its replacement and electrical parts with AC Delco or sometimes Delphi. It's all the original stuff that came on your car.
Old 08-09-2022, 09:28 AM   #9
NOT A 45
NOT A 45's Avatar
The AC Delco number I gave him was for the actuator
Old 08-09-2022, 09:28 AM   #10
Joe.G
Joe.G's Avatar
Yes, Just making sure nothing changed, I worked at a large GM Dealer in the early to Mid 90's but things do change and was just checking.
Old 08-09-2022, 11:10 AM   #11
gtstorey
I just wanted to point out that there is more than one part # that you will see it listed under, depending on where you are looking.
As far as actual manufacturing, a lot of is still various manufactures that AC subs out to.
Not sure how the various "tiers" figures into this discussion. It probably doesn't for uncommon parts like the blend door.
Old 08-09-2022, 12:34 PM   #12
NOT A 45
NOT A 45's Avatar
Great point here....I can tell you from the discussions I've had with my GM field engineer, the problem was with the vendor. That said, make sure you only get your door from the dealer, and also make sure it's the latest part number. Look at the box carefully...make sure a new part number sticker wasn't placed over the old one and also that the number wasn't scratched out and a new one written on the box! I've seen this many times! I replaced the door in my personal car in '15 and used the updated part. Haven't had a problem since!
I've seen a lot of misinformation post's on here about blocking off heater cores heat and that's the cause of the broken doors. That's bullshit! Almost all of our vehicles use a similarly designed hvac module. Other than Equinox and Colorado I have seen no failures in any of them. Don't cheap out, don't hack your car, have the door replaced with the updated part and you'll likely never have the problem again.
Old 08-09-2022, 12:57 PM   #13
Joe.G
Joe.G's Avatar
Not 45 are the # Listed here either AC or GM the up to date Numbers?
Old 08-09-2022, 01:11 PM   #14
NOT A 45
NOT A 45's Avatar
Not sure but I would assume both to be. Anything after 2014 should be the updated part. That's why I say be aware. Anytime a supersession comes about, they don't throw or return the old part, but simply affix a new part number to it. So if your dealer or retailer has had the part on the shelf for 8 years or so it very well could be the old part. Pay close attention to the label!!!!
