Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - NY / NJ / PA > Local Marketplace
Old 08-08-2022, 08:22 PM   #1
Hossram64
Drives: 2013 Camaro SS/RS
Clutch issue
I just recently had a rxt clutch and tilton slave installed. I’m having issues with the clutch sticking at start up until I drive the car a couple miles then goes back to normal. I have bleed it with the quick bleed twice now, sucked all fluid out of reservoir put new fluid in performed the bleed. Put a new cap on reservoir. Nothing seems to help. Only happens when I let it sit a day at start up. With out car engaged in gear clutch moves fine as soon as I put in first it sticks until I get a couple miles on it then perfectly fine issue goes away for the day. I did order the seperate reservoir and LF spring to install.
Hossram64 is offline   Reply With Quote
