Old 08-09-2022, 08:55 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Any Relearn Needed when adding Ported Throttle Body?Pedal Commander Leave or remove?
Hi,
I have a ported throttle body coming shortly, Did you guys do any TPS/Idle relearn when swapping the TB? Disconnect Battery or anything?
I currently have a Tune ( Mods below ) and a Pedal Commander, What are your guys experience should I remove the Pedal Commander?
No Tune needed from what I am told/researched.
Thanks
LSA SBE, Kong Ported LSA SC Reinforced Brick DM Billet Coolant Manifold with NW 103, ID 1050X,Roto Fab Big Gulp, 2.55 Upper 5% ATI Lower. AFCO HX, ProSpeed AUX Tank, MM Wild Catch Can SW Ceramic LTH/NPP, ZL1 FP JMS BAP, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace,3.91/TrueTrac Monster Triple Clutch OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors
783 HP 720 TQ on 93 Oct.
Joe.G is online now   Reply With Quote
Old 08-10-2022, 08:09 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
As far as the pedal commander, never had one, so I can't comment on that. But as far as a re-learn, I just disconnected my battery, as you should always do that when disconnecting any electrical component to de-energize it. Swap it out, connect it back up and reconnect the battery and go drive it as you would normally would, that's all I did. Noticed the difference right away, quick and a lot more crisp on the response. You might want to take the pedal commander off and see how you like it, you might be surprised. Good luck!!
Old 08-10-2022, 09:30 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I didn't even disconnect the battery and I flipped it upside down to make room for a nitrous plate. No issues. I did have to do a relearn when I did a compression test because I had to hold the throttle blade open with a screw driver while I did the test.
Old 08-10-2022, 09:39 AM   #4
Joe.G
Joe.G's Avatar
Yes That is what I figured I would do just figured I would ask, I believe shutting Pedal Commander off puts it back to Factory.
Old 08-10-2022, 04:12 PM   #5
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Correct.
0stones0 is offline   Reply With Quote
Old 08-10-2022, 08:54 PM   #6
Joe.G
Joe.G's Avatar
I should have it by the end of the month, I installed the Pedal commander a last week and honestly have not even tried it yet besides moving it around in my shop, I would like to take it off just because it is one less thing to go wrong so I am hoping the Ported TB will do the job, When I first purchased the car the clutch and the throttle were the first things I noticed needed work.
Old 08-12-2022, 07:08 AM   #7
oldman14ss
Drives: 2014 1ss camaro
joe.g. may i ask which throttle body did you purchase and what size. that is going to be my next mod this winter.
oldman14ss is offline   Reply With Quote
Old 08-12-2022, 08:16 AM   #8
Joe.G
Joe.G's Avatar
A new OEM unit ported by BO.
Old 08-12-2022, 08:37 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This is the best one to have!! Bo does an awesome job on these.
Old 08-13-2022, 01:45 PM   #10
oldman14ss
i will go with bo later next month have to hide it from the better half. happy wife, happy life. shes put up with 30 years of me and 20 of it was wheb we both were on our harleys. me and that old gal road alot of highway together
Old 08-13-2022, 01:51 PM   #11
Joe.G
Joe.G's Avatar
Yeah I wanted one of his for a while I am glad I was able to get my hands on one.At some point I'd like to get a GPI Modded Intake.
Old 09-06-2022, 08:03 PM   #12
Joe.G
Joe.G's Avatar
Installed the Ported Throttle Body today and installed new battery at the same time, I used a torque wrench but I ended up stopping at 95 Inch pounds ( Spec is 106 Inch pounds ) since it really felt like it was getting tight. Car started right up but the RPM gauge was gong crazy and I had an ABS and Service Power steering warning message on dash. I unplugged the MAF and TB Plug and plugged them back in and everything went away.
BO's work looks great and working with him was very easy. Thanks again BO.
I can't say how it works on the road as it is finally raining here so it will be a few days before I get the car out.
Old 09-06-2022, 08:34 PM   #13
Joe.G
Joe.G's Avatar
Photos of ported and stock attached.
Old 09-06-2022, 09:15 PM   #14
Bo White
Bo White's Avatar
Thanx bud. I just happened to run across that new TB when I was cleaning my workshop out. Glad you wound up getting it.
Most usually ditch the pedal commanders after a ported TB. Sometimes errors are thrown when ran together because it's too much.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
