Old 08-14-2022, 12:08 PM   #1
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
High iats
What are you florida guys doing for high iats? I have ecs 1500 kit and I'm wondering is my only option to run meth.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 08-14-2022, 01:39 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Meth won’t cool it that much. I run 1000 cc in the intake and 450cc directly into the supercharger lid. 100% meth
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 08-14-2022, 06:45 PM   #3
DARKTHIRTY777
DARKTHIRTY777's Avatar
Drives: 2011 camaro ss
I recently bought a vented carbon fiber hood and bought the bigger intercooler for my ECS 1500. We shall see how that helps after I install it.
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
DARKTHIRTY777 is offline   Reply With Quote
Old 08-15-2022, 01:56 AM   #4
Shodown
Shodown's Avatar
Drives: 2014 ZL1
My IATs are usually 35°-45° below ambient temp with my Killer Chiller. I live in AZ now but just moved from GA where it's much like FL with the humidity.
This pic was taken in GA.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 08-15-2022, 07:23 AM   #5
Surfdog SS
Surfdog SS's Avatar
Did you have the older upright intercooler? I'm wondering if that's the one I have now, since it's not that upright one.
Old 08-15-2022, 09:51 AM   #6
Surfdog SS
Surfdog SS's Avatar
Can you use that with a centrifugal sc?
Old 08-15-2022, 11:28 AM   #7
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
IAT sensor and location are important. Did you separate and relocate it from the MAF? Choose and using a different sensor (e.g., Rife)?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 08-15-2022, 12:18 PM   #8
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
My IATs drop 20 degrees on 100% meth, but I did the divorced IAT sensor like Dreksnot mentioned.
Old 08-15-2022, 12:20 PM   #9
Surfdog SS
Surfdog SS's Avatar
I don't believe we did. The maf was reused in the new pipping that came in the kit. And we swapped out the map for a 3 bar.
Old 08-15-2022, 12:32 PM   #10
dreksnot
dreksnot's Avatar
MAP and MAF different. The MAF is usually about 18" upstream of the throttle body. Many inject meth about 6" before the throttle body which would be after the IAT sensor so one couldn't see the temp reduction of the meth. That's why I asked. Where are you injecting meth and where is the IAT sensor (MAF, not MAP)?
Old 08-15-2022, 12:49 PM   #11
Surfdog SS
Surfdog SS's Avatar
Currently not injecting meth. I'm just asking what are my options to deal with high iat. And if meth is the only way. The maf is located around 12-18 in front of the throttle body in the new pipping. So what your saying is it has to be before the maf to read correctly.
Old 08-15-2022, 01:08 PM   #12
dreksnot
dreksnot's Avatar
I'm not injecting meth. I'm just asking what are my options to deal with high iat. And if meth is the only way.
Ok. I have been trying to avoid using meth for years. When running my SBE LS3, I relaxed my spark reduction table (IAT Spark Advance Correction - Add) so that the ECU would not start pulling timing until much higher temperatures and pull less timing. I was able to run up to 15psi before temperatures got a little toasty for me (got nervous). After LSX'ing and going bigger turbos, I decide to try 100% water injection and moving the IAT sensor to behind the throttle body. Must moving the IAT sensor was a huge eye opener. Much faster readings and showed actual in the intake manifold air temperatures. Then, with the pure water injection showed marked IAT's reductions. After doing that for a while I wanted a little more protection (adding octane) so I am trying a 50/50 meth/H2O mixture. I haven't gotten a chance to go out and play hard (25+ psi boost levels). That all said, water and meth WILL reduce IAT's, in my case 30-40*F easily with just water, more with meth. Just moving the IAT sensor (and using a Rife), the temperatures appeared lower at high boost, but higher during cruise - that alone may "remedy" your high IAT's itself.
Old 08-15-2022, 01:30 PM   #13
Surfdog SS
Surfdog SS's Avatar
Great info thank you
Old 08-15-2022, 08:35 PM   #14
DARKTHIRTY777
Yes. I have the older upright one now. The little intercooler.
