![]() Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Wheel Shaking
I have a 12 2ss manual. It has 92k miles I just got new wheels and got them balanced twice now. They said the wheels were fine and the wheel likes to shake bad around 50-70mph. any ideas. its not rotors because it doesnt happen when i just brake.
![]() Drives: 98 z28 stalled a4, 2010 ss m6 Join Date: Jan 2016
What’s size wheels and tires? If you ran a wider tire than your wheel that can happen.
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
I have occasionally had problems with inexpensive china made wheels. Not sure what you have, but it makes sense the problem didn't start until you replaced the wheels.
They probably aren't balanced properly. I went through that a couple of times, they found the weights were placed in the wrong spot on the wheel. Did they do a "road force" balance?
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
Mine does the exact same thing. I'm going to try road force balancing next. My wheels are Niche Milans. Running 275 front 315 rear.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
The wheels/tires may be a bit out of round ??
#7 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Ask them when’s the last time they calibrated their balancer according to the manufacturer’s procedures. An electronic balancer that’s out of calibration will indicate the wrong correction weight in the wrong location. (Angle) In other words, it’s not properly balanced, though it tells them it is.
| Tags |
| shake, steering, wheel, wheelshake |
