Old 08-23-2022, 11:00 AM   #1
carlc376
carlc376's Avatar
Drives: 2010 Chevrolet Camaro v6
Dashboard right turn signal indicator not working all the time
I am new to the Camaro, but I suspect this can happen with any car. I have owned quite a few cars (older and newer), but have not seen this before. When I turn my right blinker on, the dash indicator works only some of the time. The right, outside blinkers are working as expected. The left dash signal indicator works all of the time. When the hazards are on, I only see the left signal indicator. I have not yet pulled the cluster apart to see if there may be a loose connection or corrosion.
Has anyone else had this issue and if so, what was your solution.
Chris
2010 Camaro
Transformer Edition
carlc376 is offline   Reply With Quote
Old 08-23-2022, 11:21 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Sounds like bulb specific and/or wiring to the bulb. Think your on the right track checking connections.
0stones0 is offline   Reply With Quote
blinker, dash
