Old 08-24-2022, 05:27 PM   #1
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
Turbo Flyby Video with boost
Been a while since I posted anything. Here is a new video doing some side by side pulls being filmed so you can hear the boost kick in with a hood exit. If you like turbo spool, this is for you. I always wanted to know what I sounded like passing people!
Forged 6.8L BTR 416 Stroker kit with K1 crank and Wiseco pistons (10.5:1)
Huron Speed single turbo kit for 5th Gen with Turbonetics 78mm/1.15 ar, oil cooled BB turbo
Intercooler
Deatchwerks 90# Injectors & ADM FPCM and ZL1 Fuel pump
3 bar map sensor
8psi boost & ported TB
Chromoly rods & LS7 lifters
BTR dual valve spring kit
230/234 114 LSA .621/.603 Cam Motion cam
25% Powerbond UDP
Might Mouse CC
ARP head & cam bolts(not studs)
Twin disk Monster clutch
ZL1 rear end, zl axles, zl1 driveshaft and zl1 cradle with Royal Purple
Unknown HP - Remote street tuned by Vengeance
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 08-26-2022, 08:57 AM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Wow. Give yourself a pat on the back.. That is an animal
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-26-2022, 03:22 PM   #3
chevyz1
Wife named it "Ghost"
chevyz1's Avatar
Drives: 2012 Camaro Summit White 2SS/RS M6
That sounds beyond awesome. Could listen to that all day!
2012 2SS/RS Camaro M6 Summit White
chevyz1 is offline   Reply With Quote
Old 08-27-2022, 10:20 AM   #4
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I like your build, needs a rain flap
silversleeper is offline   Reply With Quote
Old 08-27-2022, 12:49 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Looks fun! Clean looking hotrod
joshnmn is offline   Reply With Quote
Old 09-06-2022, 09:41 PM   #6
RupertPupkin
Drives: 2014 Camaro SS 1Le
Need like a 150mph fly by... like this
https://youtu.be/FCT6BXn2SbA
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
flyby video, huron speed, monster clutch, turbo, turbonetics
