Old 08-26-2022, 03:13 PM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
Clutch spring
I just did the tick hydraulic clutch unit
The problem is factory clutch spring I’m not sure which way the orientation went does this look correct or should I flip it around ?
Scotty D is offline   Reply With Quote
Old 08-26-2022, 03:15 PM   #2
Scotty D
Trying to load pic
Old 08-26-2022, 03:28 PM   #3
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Don't put it there at all.
This spring makes absolutely no sense in the function of the clutch system.
Buy spring from Lingenfelter.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 08-26-2022, 03:55 PM   #4
Scotty D
So , I can just leave it out ???
Old 08-26-2022, 08:23 PM   #5
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
I removed mine and it's never going back in. The clutch feels and operates such better without it!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
Old 08-26-2022, 08:40 PM   #6
Scotty D
Ok I’m going to bleed my tick master tomorrow
And I’ll take it out before I start
Thanks guys
Old 08-26-2022, 09:28 PM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Originally Posted by Scotty D View Post
Trying to load pic
Yes that correct. It can only fit one way. How did you fit it in (ie. did you use any tool to fit/squeeze the ends in, did you depress the pedal to make room or lesson tension)?
camguynj is offline   Reply With Quote
Old 08-27-2022, 04:44 AM   #8
George-CZ
George-CZ's Avatar
If I can advise from my own experience...
Remove it completely and replace it with a tension spring from Lingenfelter.
https://www.tickperformance.com/ling...rt-l360091410/
I still don't understand why someone put that spring there.
When I tested the difference without the OEM spring and with the OEM spring, I came to two findings.
1: The clutch pedal returns up more slowly.
2: In the end position, the clutch pedal is not so hard.
So the only thing I can think of why someone in GM put it there was because they were get scared the clutch was too hard or to make it easier for less skilled drivers to work the clutch pedal.
I have driven countless cars, tractors, trucks, bulldozers and other vehicles. But the Camaro was the only one I encountered with a clutch spring that pushes the pedal to the floor instead of from the floor.
I was totally unhappy when I brought the car and I didn't know how to drive it. Then I figured it out while bleeding when the clutch pedal disappeared under my foot.
I tossed it out installed a custom spring and felt like coming home from a party and kicking off dress shoes you've outgrown a long time ago
Of course, the OEM spring is no longer there...
Old 08-27-2022, 07:10 AM   #9
Scotty D
I just did a monster triple and they recommend using that assistant spring
Old 08-27-2022, 09:01 AM   #10
George-CZ
George-CZ's Avatar
So you see... There's nothing to worry about
Old 08-27-2022, 09:20 AM   #11
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I did the same as George, Leave the spring out. I did add the spring from the link above, You can run it with or without either spring.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 08-27-2022, 10:06 AM   #12
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I've been running my Triple Monster w/o any return spring or OEM for years. Least resistance feel. I've tried adding an assistance spring but didn't like the added resistance.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 08-27-2022, 09:30 PM   #13
Joe.G
Joe.G's Avatar
Yeah I didn't mind mine with no spring but figured a help spring may help avoid the clutch sticking some experience.
Old 08-31-2022, 09:39 PM   #14
camguynj
camguynj's Avatar
Does anyone know if any sensors are affected like cruise control if the clutch pedal doesn’t return to its stock height ?
UPDATE - per Tick “if the pedal is adjusted too low from its stock height you will have to do a pedal relearn procedure “
