Old 08-30-2022, 09:49 PM   #1
kevsbumblebee
Drives: 2010 Camaro 2SS
Exclamation P0651: Service Stabilitrak Engine Power Reduced
HELP!!!!
Have gotten the P0651 code recently and it'll throw the car into reduced power mode. Have not found a thread on here that fully explains this. Replaced the throttle body as one of the threads on here recommended but the problem still persists.
2010 SS L99 AUTO
kevsbumblebee is offline   Reply With Quote
Old 08-30-2022, 10:15 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Just to make sure, you don't have an aftermarket throttle controller installed, correct?
Old 08-31-2022, 03:15 AM   #3
kevsbumblebee
To my knowledge no. An air intake plus headers and catback is all i have on the car so far.
Old 08-31-2022, 07:44 AM   #4
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Originally Posted by kevsbumblebee View Post
HELP!!!!
2010 SS L99 AUTO
Try this.....
The 5 V reference 2 circuit provides 5 V to the following sensors:
APP sensor 1
Throttle position sensor 1 and 2
Crankshaft position sensor
Brake booster vacuum sensor
It may be possible to locate the fault by disconnecting one component at a time from the affected 5 V reference circuit while viewing the 5 V Reference Circuit Status parameter on the scan tool. The scan tool parameter will change from Malfunction to OK when the source of the fault is disconnected. If all 5 V reference components have been disconnected and a fault is still indicated, the fault may exist in the wiring harness.
NOT A 45 is offline   Reply With Quote
Old 08-31-2022, 09:01 AM   #5
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
Doesn't this code sometimes show up when the battery has issues ? idk
2014 2SS/RS AGM L99
CAI Intake
ELITE Catch Can
POWERSTOP Brakes (5/31/21)
romcjr is offline   Reply With Quote
Old 08-31-2022, 09:24 AM   #6
NOT A 45
NOT A 45's Avatar
Low voltage creates all kind of phantom codes but usually the are accompanied by communication codes (u codes). He only spoke of 1 code so I doubt it's battery related.
Old 08-31-2022, 09:33 AM   #7
gtstorey
That's assuming he has a code reader that can read beyond P codes.
Old 08-31-2022, 05:50 PM   #8
Miami_SS
Drives: 2011 Camaro SS LS3
HELP!!!!
2010 SS L99 AUTO
I received this code when I used a throttler controller. I took off the controller. When you put the throttles (stock to aftermkt, aftermkt to stock) on your Camaro did you do the throttle re-learn process? That could be why you're still getting the code. I also got a REP (Reduced Engine Power) when my accelerator pedal was on the blink. I replaced the pedal and no more REP. Hope this helps.
Miami_SS is offline   Reply With Quote
