Old 09-15-2022, 03:57 PM   #1
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
Methanol Install
I'm planning a trunk tank for my methanol kit. How did you run the line from the trunk tank? I'm thinking underneath the passenger side of the car since the centrifugal pipe comes up from that side. Did you run it through the air box like fuel lines? Any info would be appreciated on the path you guys took.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 09-15-2022, 04:42 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I ran mine through the interior of the car, down the door sill and through the firewall.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 09-16-2022, 07:57 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I ran the lines out the bottom of the trunk and the pump is right there. I have a good bit of electronics in the trunk like remote control switching and relays for N2O, BAP and line lock. I ran the line up the driver's side, but I have the N2O line running up the passenger side. I don't see a lot of difference although coming up the driver's side puts me a hair closer to the ports on the intake I spray through.
Old 09-16-2022, 10:08 AM   #4
Surfdog SS
Surfdog SS's Avatar
Thanks for the info, did you guys seperate the iat sensor also
Old 09-16-2022, 10:33 AM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
"They" say "don't run anything flammable through the cockpit." On that note, I ran my meth line from the battery well tank, driver's side of the trunk behind the rear seat, under the driver's door sill (following the main positive power line), through the dash bulkhead behind the instrument panel, to my intake tubing before the TB.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 09-17-2022, 08:17 AM   #6
Surfdog SS
Surfdog SS's Avatar
Where do you guys get your methanol from?
Old 09-17-2022, 08:58 AM   #7
CamaroCracka
I moved the IAT to just before the TB and you can see the drop in IAT in the scans. My tuner does not like to advance timing based on IAT with the turbo just in case the meth runs out. I know, if the meth runs out the IATs would go back up, but I did the meth more for insurance against detonation and did not want to take it to the ragged edge just yet.
I get my meth from Space Coast Speed and custom. I've also gotten it from the Speed Shop in Longwood, but Space Coast is closer for me. FYI, Space Coast is off the main road and Rob is pretty much dedicated to machining for race engines etc. so he does not need a store front and stays very busy. If you are using a mix, you can get premix from the kit vendors or even use -50 degree windshield washer fluid if you can find it.
Old 09-17-2022, 10:59 AM   #8
dreksnot
dreksnot's Avatar
Local racetrack sells race fuels and E85 for a good price
