![]() Drives: camaro ss 2010 Join Date: Apr 2022
PLEASE HELP-Camaro SS- 2010 tail and fog lights problem
Hi hope someone can help me with this problem to find out what could be...
The 2 lights on the passenger side and quarter lights do not turn on if I want to use the lights at night, the tail lights work if I put the turn signals, stop and flashing lights, the othe side from the drivers work fine the fog lights stop working, could be a fuse problem? Also the side light from next to the tail light stop working. Last edited by bajacamaro; 09-16-2022 at 03:42 PM. |
Let's tackle the easy one first...the front "fog" lights are actually your day running lights. From the factory, these will only come on when the car is running and the switch in the "Auto" position. (Also, the parking brake will need to be off for them to come on). Once the parking or headlights are turned on, the day running lights will shut off.
The harder one is the tail lights/side marker. Since the driver's side lights are on, it sounds like there is something more going on that needs to be investigated. Have you recently done anything with the lights or wiring on the passenger's side? |
#3 | |
Ah ok...it's possible it could be in the new harness. Not to state the obvious, but before you start pulling the back bumper off, have you tried replacing one of the tail bulbs or swapping it with one from the driver's side?
Check bulb connections for rust especially with yours being 12 yrs old. My passenger side marker stop working. When I went to change the bulb I noticed the connector was rusty so I replaced it and the bulb after first putting dialectric grease on both.
#6 |
Hi I try changing the bulbs and nothing, from the fog lights I drive the car using the auto mode and nothing
Here a short video where you can see if I used the remote control to open the car the light will go on, but will keep off https://files.fm/u/ym5h2rkbk |
