![]() Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
What types of oil and oil filters are you using on high mileage 10-12 Camaro 2SS V8?
What types of oil and oil filters do you run on you're high mileage 2010-2012 Camaro 2SS 6.2L V8?
![]() Drives: chevy camaro ss Join Date: Apr 2020
Mobil 1 high milage and mobil 1 filter currently at 258000 trouble free miles.
![]() Drives: 2013 ZL1 Join Date: Sep 2021
As long as you change it regularly with quality components it really doesn't matter,
376 cubic inches of fun
Mine has 80k plus miles. Using Delco PF 48 and lately PF 48E filters, and Mobil 5W-30.
All by the book. Oil changes have been either using the oil life indicator or once a year, depending on circumstances. After 12 years, no discernible oil consumption. |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Really, it's whatever you choose, just change it when needed. I've used it all. I currently use vr1 and upf48r.
More to come. |
#6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Sumbitch, that’s a lot of miles on any motor! Good to know.
#7 |
AMSOIL 10W40 Zrod with WIX or K&N Filters.
However, I track mine in the hot summers and was recommended to use at least 5W40 for hot track work. Was using AMSOIL 5W30 before then. I also change my oil halfway through track season with about 1500-2000 miles on the oil. But that is specific for me and my use case. Like most have said already, changing the oil regularly with good oil/filters is the more important then what you use.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
#8 |
Drives: 2013 ZL1 Join Date: Nov 2018
AC Delco filter, Mobil 1 0w 40 Euro on a 113,000 mile ZL1
#9 |
![]() Drives: 2010 Camaro 2SS Join Date: Jul 2021
Pennzoil ultra platinum and AC Delco filter
#10 |
![]() Drives: Dusk SE Join Date: Jun 2014
Amsoil with a K&N filter for the win.
Daily Drives Dusk SE 2SS/RS
#11 |
![]() Drives: 2012 SS Join Date: Dec 2021
ac delco filter. mobil 1
2012 Camaro SS
#12 |
![]() Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Tumbleweed, you are the only one! I guess you got the only good one they made!
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
#13 |
#14 |
![]() Drives: 2011 Camaro SS Join Date: Jul 2022
I use Mobil 1 5W-30 and WIX WL 10255 or K&N 2011, they are a little bit bigger filter. Maybe it helps maybe it don't, but it can't hurt in my opinion!
