Old 09-19-2022, 12:59 PM   #1
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
Console aftermarket gauges
Has anyone found an aftermarket gauge set to go in the center console? I'd like some gauges there with a little more resolution or even digital gauges.
Kings2010 is offline   Reply With Quote
Old 09-19-2022, 06:05 PM   #2
BatmaroBeauty
BOOST OR BUST
BatmaroBeauty's Avatar
Drives: 2010 Camaro 1LT
https://www.autometer.com/direct-mou...E&gclsrc=aw.ds
^Autometer makes this dual pod cluster for the center console but this particular console pod is designed to be used on the Camaro models that feature the tray there and no gauges. It's not designed to replace existing gauges if your model has the optional 4 gauge pack in front of shifter. Same pod is also available on phasteks website linked below.
https://www.phastekperformance.com/2...o-pod-5286.htm
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . .
BatmaroBeauty is offline   Reply With Quote
