Old 09-19-2022, 08:53 PM   #1
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
l99 engine upgrades
Evening guys. So I'm currently having my engine rebuilt at a secret little shop around here in Austin where all the engines this guy builds are LS's. He's been around for a long time and has a good reputation and he works by himself and is always busy, usually takes 6-7 weeks to do an engine but he's definitely worth the wait. I have all my parts pretty much picked out except I was wondering what you guys use for a l99 timing chain and gears as an upgrade? Is it the same chain as a ls3? Do I need to buy a new cam phaser to get the correct cam gear? Thanks
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 09-20-2022, 09:00 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I think we used the Katech chain in my build..
Old 09-25-2022, 11:03 PM   #3
Vicster
Drives: 13' ZL1
I used stock LSA parts, compared it to Cloyes and Katech. I liked the stock chain better! That is what I have put intio my 427ci build. You do not need the phaser if you are not going to use it, a standard gear will do.
Vicster is offline   Reply With Quote
Old 09-25-2022, 11:05 PM   #4
Vicster
Drives: 13' ZL1
I saw that you had issues with piston to intake valve clearance. Any chance you took pictures? I was wondering if it was piston notch clearance or if you cam was off.
Hope you post pics of the new engine and install!
Thanks, Vic
Old 09-26-2022, 04:24 AM   #5
morepowerjoe
Did you have vvt though?
Old 09-26-2022, 04:25 AM   #6
morepowerjoe
Thanks, Vic
My tuning shop has a picture, I'll try and get it from him and I think I might start a build thread.
Old 09-26-2022, 05:13 AM   #7
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Used stock replacements on mine for both cam swaps.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 09-26-2022, 10:01 AM   #8
Vicster
Drives: 13' ZL1
Nope sorry, the ZL1 does not have VVT, it was about performance not fuel economy...
I cannot wait for you to start your build journal!
This is a good read;
https://www.onallcylinders.com/2017/...-an-ls-engine/
Old 09-26-2022, 10:15 AM   #9
morepowerjoe
Well here it is
https://www.camaro5.com/forums/showt...1#post11234179
