Old 09-20-2022, 02:12 AM   #1
PlymouthBarracuda
Drives: 2011 Chevrolet Camaro SS L99 AT
Question Noise, clicks, delays in DIfferential
Hello, could anybody advise me with my differential issue..
Unusual noise is coming from the diff, dips and delays are felt when releasing throttle and subsequent acceleration.
This constant extraneous noise presents always, but it's best at speeds 40-65 mph, the higher the speed, the higher the pitch of the sound.
Metallic clicks are also often heard when starting off. I checked the CV Axles but no backlash was found. The only play is inside the differential, if you check through the drive shaft..
The dips and delays are very similar to the late operation of the solenoids in the automatic transmission, however, my tranny and TQ are after disassembled full revision, with replaced TCM.
I bought everything but in doubt, do I need something else for diff restoration ? I bought for GM 8.6" IRS and hope it's exactly my diff.
Gear oil ACDELCO 104016 and additive for LSD ACDELCO 104003.
PlymouthBarracuda is offline   Reply With Quote
Old 09-20-2022, 08:03 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The clicking could be lack of or worn axle washers. Go between the axles and hubs. Literally say anti click on the parts catalog. GM part number is 11611965.
As for the fluid. You can get ac delco fluid with the ls additive. GM part number 89021677
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-20-2022, 08:37 AM   #3
gtstorey
I don't know that a worn diff is causing "dips and delays". If I remember correctly you have a fairly low mile car?
gtstorey is online now   Reply With Quote
Old 09-20-2022, 09:32 AM   #4
PlymouthBarracuda
Thank you very much ! I replaced left CV Axle 3 month ago with Trakmotive, but clicks returned (maybe diff sound?). By sound, I meant a drawn-out howl, like on old trucks. In my understanding, bearings are collapsed and pinion ring is worn out
Old 09-20-2022, 09:35 AM   #5
PlymouthBarracuda
No, mileage is 105633. I bought it used, previous owner loved to drift on the track.
Old 09-20-2022, 11:52 AM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
So it appears you have a full rebuild kit coming for the rear along with new gears, Now I am not saying this is your issue or not but if I were you and doing all that you really should rebuild or replace your Differential, they are known to wear, I would install a True Trac ( Which I did in 2 of my vehicles ) or at least a stock type. and 8.6 IRS is correct.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 09-20-2022, 12:43 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Howling is usually pinion bearing related. A full rebuild with a trutrac may be needed.
More to come.
Old 11-16-2022, 09:26 AM   #8
PlymouthBarracuda
Question
Replaced 3 bearings, shims, diff main ring and pinion, applied additive Delco 88900330, but no changes in terms of sound. The howling sound from the back of the car remained. It depends only on the speed of movement, but not on pressing the gas pedal.
Maybe you have any thoughts on this case...
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver
Old 11-16-2022, 09:55 AM   #9
PlymouthBarracuda
There are MEVOTECH H512399 rear wheel hubs in our local store , will try to replace them
Old 01-14-2023, 09:53 AM   #10
RoadRunner70
Drives: Chevy Camaro SS 2012 Auto/TR
I had the same howling noise constantly at 35-65 mph and replaced differential main ring and pinion.
Now, after replacement, I have the same when throttle is applied only...
Adjustment was done by diff repair station with a dial micrometer.
Any suggestions ?
RoadRunner70 is offline   Reply With Quote
