376 cubic inches of fun
Jammed seat back release.
OK, so I have the TBS for this problem and have lubed the release mechanisms with the recommended dry lube. That worked for a while, but now both seat backs on my 2010 are jammed again.
Has anyone found a long term fix other than repeatedly taking the upholstery off and spraying copious amounts of dry lube in the general direction of the release mechanism? |
#2 | |
![]() Drives: 2014 Camaro 1LT Join Date: Aug 2019
I didn't know that this was a thing. How long did you have your car before this problem occurred? |
#3 | |
A few years later, the driver side release stopped working but I didn't care because it was easy to use the passenger side only to access the rear seat. No one ever sits there; access is for cleaning and cargo only. Now, in late 2022, the passenger side is jammed again, so I'm wondering whether anyone has found a mod that works better than just lubricating the obviously ill-designed mechanism. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Mine gets in a bind and hard to pull sometimes. When that happens I just wiggle the back of the seat back and forth and it works. It's like it's not actually jammed, just in a bind and you have to release the tension so it can move freely.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
crap...first the a/c suckage and now this...
#6 | |
#7 | |
Of course, power reclining gets you to the same place, but it takes forever. |
#8 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Same here,i have never lubricated the mechanism.
#9 |
No passenger side is very bad.Where can i put lubricant ?
#10 |
![]() Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
I just hold the handle up and give the seat a shove backwards and it releases.
#11 |
![]() ![]() Drives: 2011 2SS/RS LS3 VR Join Date: Aug 2009
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
15 years for my '10SS. No big deal.
