Old 10-05-2022, 09:01 AM   #1
Olov
Drives: Camaro 2SS RS 2015
Missfire P0300
I still have big problem.. 2015 SS about 55k miles, got misfire and have checked that I have ground to all coils, have signal from ECM to all coils, have spark on all plugs, I have signal from ECM to all injectors, I have power from fuse to all injectors, no bent pushrod, I have "stripped" all cables around the engine and it all looks good..
missfire on 2 and 4.. BUT.. there was a strange thing, when we were trying to find anything, we by misstake damages one groundcable that fits on the backside of the head.. there is on on the right side and one on the left.. the one on the left goes direct to the coils but the one on the right side (the one we took loose) goes together with many other cables ..
The strange thing is that when that groundcable was lose I hade missfire on 2 and 4 and when we did hold it against ground the missfire moved to 4 and 6 ???.. I did fix that cable and bolted it back to the back off the head.. and now I have missfire on 4 and 6
I think it has to be some fuel problem, as I have spark.. and the sparkplug is not wet...
anyone that has a good idea??
Olov is offline   Reply With Quote
Old 10-05-2022, 09:38 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Checking fuel pressure would be reasonable.
0stones0 is offline   Reply With Quote
Old 10-06-2022, 03:45 AM   #3
Olov
no problem with fuel pressure... :( have lifted the heads off.. no problem there that i can se... sending the heads for checkup...
Old 10-06-2022, 10:06 AM   #4
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Did you do a compression check? I'm not a mechanic, but I've seen several guys get misfires due to low compression in a cylinder.
ElderJ is offline   Reply With Quote
