Old 10-07-2022, 08:31 AM   #1
2012CamaroSs45
Drives: Chevy Camaro
PLEASE HELP
I’m hoping somebody can help me with my problem I have been getting a message on the dash saying engine power reduced followed by code p0601. The car will idle for a couple minutes and then just cut off.. I checked other forums and a lot of people are saying it could be the voltage but I went out and bought another battery and I’m still having the same issue. My guess is either a bad PCM and to check the wiring to the PCM.. wanted to know if there is anything I can get before I go out and replace my PCM
2012CamaroSs45 is offline   Reply With Quote
Old 10-07-2022, 09:04 AM   #2
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Needs the ECM. It isn't a wiring issue, it's a fault internal to the engine computer.
NOT A 45 is offline   Reply With Quote
Old 10-07-2022, 04:43 PM   #3
Johnh7
Johnh7's Avatar
Drives: 2012 2SS 45th Anniversary Edition
Clean the throttle body. The system senses it is dirty and shuts down. Once you clean it, it should run fine. I attached pictrues of mine before and after. Once it was wiped out (it came right off) the car ran great again.
John
Kooks longtube headers and high flow cats, K&N CAI 63-3074, BBK 95mm throttle body, Flowmaster Mufflers, SCT Tuner
Johnh7 is offline   Reply With Quote
