Old 10-07-2022, 03:57 PM   #1
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Need help w idle
My 18 yo just got a 2010 2SS that he loves. Of course dad can't leave anything alone .
I was looking through the tune and it looked like a stock tune... Mostly. Someone had gone in and essentially defeated traction control (enable RPM 8k+). So anyway, I returned that to stock and then disabled DoD. That's it, then wrote it to the ECU .
First time I started it I couldn't get it to idle. Had to put about 20% throttle to keep it running. I fought with it all day yesterday, doing tb relearn, disconnecting battery, everything. Still no luck.
I left the battery unhooked overnight, reconnected it and it started right up and idled perfectly... For about 30 seconds, then started losing its mind again.
Any thoughts? Anyone know what happens around 30 seconds in the startup script?
joshnmn is offline   Reply With Quote
Old 10-07-2022, 04:09 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I hope "someone" had mind enough to save the starting tune (one on the car before implementing changes) before flashing. Just reflash the original and go from there. If "someone" didn't.....
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 10-07-2022, 05:59 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Already done. Same results
Old 10-07-2022, 06:16 PM   #4
dreksnot
dreksnot's Avatar
What has been done to the car (mods)?
Idle Startup Airflow only tapers for 4 seconds. Engine coolant and inlet air temperature affect idle; changes spark, airflow, fueling and tables that modify those parameters.
Generally speaking, airflow is the highest culprit in idle tuning, and heavily relates to my first question above.
Old 10-07-2022, 10:15 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
It has a CAI and no mufflers, which I guess might* improve airflow, but it had the stock tune in it before and ran fine
Old 10-08-2022, 07:16 PM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
I let it sit overnight and tried this afternoon. Same results
I think that would tend to eliminate any temperature effect.
Old 10-09-2022, 01:22 AM   #7
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Idk buddy. You goofed something up. Maybe you thought you saved the original tune but didn't because it has no reason not to run the same if you loaded the previous tune correctly. I would do a data log and watch the throttle % and see if the throttle is actually closing on you. Also see if it's in closed loop or open loop when you first start it, I believe it should be in open loop, check your fuel pressure, and make sure your AFR is commanding at 14.6. That is the extent of my knowledge of tuning. Sorry just trying to help.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-09-2022, 01:25 AM   #8
morepowerjoe
One other thing I was thinking about is maybe whatever the ecu had learned was apparently lost and maybe it just has to relearn whatever was lost?
Old 10-09-2022, 01:50 AM   #9
joshnmn
2&THEHIT
joshnmn's Avatar
That's exactly what it needs to do. I just don't know how to get there from here.
Old 10-09-2022, 11:58 AM   #10
dreksnot
dreksnot's Avatar
Sounds about right. When approximately 20sec after startup and shifting over from OL to CL, your O2 sensors have heated up and start to command AFR. Log "Fuel System #1 Statue (SAE) and you can see if this transition is the point at which your idle goes south. If so, then your airflow or fueling is highly suspect. Possible that an O2 sensor is faulty too. That being said, have you compared your current tune with a stock tune downloaded from the HP Repository (make sure it's a real stock tune and not one that someone uploaded claiming it's stock (download multiples))? As for an ECU "relearning," that usually means it's using/calculating LTFT (long term fuel trims) for idle/cruise - determining a "saved" amount of extra or less fuel to add/subtract to keep the engine running at Stoich during idle/cruise. You can clear those (temporary) numbers going into the Diagnostic and Info in the Scanner. However, generally the STFT (short term) would compensate until the LTFT catch up while running over time. Still, lots of things that could be considered. Wouldn't hurt to load up your tune and a log here to show what's happening.
Old 10-09-2022, 01:20 PM   #11
joshnmn
2&THEHIT
joshnmn's Avatar
Thank you for the input. That is exactly what I have been looking for and felt was the culprit.
Yes, I have compared the tune to several stock tunes (and also the not stock tunes). That's how I found out that the traction control enable/disable is the only cell that was different.
I'll definitely log the fuel status PID and force it to open loop. That's the answer- Something to show when it shifts to closed loop. Thanks!
Old 10-09-2022, 01:35 PM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
What tuning software are you using to flash?
FasNuf is offline   Reply With Quote
Old 10-09-2022, 06:57 PM   #13
joshnmn
2&THEHIT
joshnmn's Avatar
HPTuners
Ok, getting somewhere now. First attempt today it started right up and idled great, right up until it went into closed loop. I had PID "closed loop active" on my channel list and it went to Yes and the car started spitting and sputtering so I shut it down. Didn't save that log because I thought we nailed it.
So the I failed it to open loop (O2 readiness temp to 400) and tried it again. No change, won't idle and I have to give it ~25% throttle to keep it running. Fudge
Last attempt was weird, and I did save that log. I'll upload it tomorrow. While I was holding it steady, the RPM (and O2/spark) would hunt every second or so. RPM would change from 1800-1200 and back with no throttle change. Again, all open loop.
Next things to do are swap MAP, then MAF sensors.
Old 10-09-2022, 07:15 PM   #14
FasNuf
FasNuf's Avatar
Did you try WRITE ENTIRE?
