10-16-2022, 12:26 AM | #1 |
First time modifying vehicle questions about tune
So i had my car torn down and had some parts thrown in at my shop. Tuned the car with the cam made 473whp. However at the same time i put on headers that are catless, i plan to get high flows soon. But i also have a NPP exhaust, being catless and cammed/tuned would i need to worry about a re-tune typically by setting up a controller for the valves and running it closed at idle/low speed when im leaving my apartment complex? Wouldnt expect to do it but 10% of my driving time and not under hard accel. Not sure if it would add "backpressure" or throw things off majorly. First time modifying a car (outside my mustangs catback & k&n intake.
Thanks, 2013 Camaro SS M6 Parts -Speed Engineering Headers -TSP Stage 3 Cam -JLT Intake -misc. pushrods/trunnion/springs/lifters etc. |
10-16-2022, 07:17 AM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Don't need tune for the baffles. Keep it open. Minimal sound difference. People use mild to wild switch all the time. I opted out for that feature and just did a muffler mod.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
10-16-2022, 09:34 AM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I would imagine you will need to retune it after you install the cats.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
10-16-2022, 09:38 AM | #4 | |
It don’t come easy.
This Adding the cats will definitely change how she breathes.
10-16-2022, 10:31 AM | #5 |
I appreciate the responses I am looking to build my own controller for the valves. And I do expect to retune after the cats just figuring a valve controller could be a potentially cheaper and quicker solution to save my lease ��. With no cats and a xpipe she is very rowdy and I love it, just thinking the neighbors windows 10ft from the car may not at 6:30am.
10-16-2022, 10:50 AM | #6 |
I'm catless and my air fuel ratio has no change when I open my NPP exhaust. Cats will need a retune if you install them. As far an a Mild 2 Wild goes, you don't need to buy one. A simple switch is all that's needed. I went a little overboard, but here's a video of mine.
https://youtu.be/R1WfpAotXIY . . . . . . .
10-16-2022, 01:20 PM | #7 | |
10-18-2022, 03:31 PM | #8 | |
10-18-2022, 03:32 PM | #9 |
