Old 10-16-2022, 10:47 PM   #1
Gstick
Drives: 2015 Camaro SS/RS 1LE
Springs with B6's
I have 4 new Billies B6's & am curious what springs would match up properly.
I do not track my car but I do like to walk away from a friends Boss 302 when he tries to follow me in the corners out on country roads. I also have the dreaded "bang" with the 1LE struts so I figure while I replace them might as well upgrade the springs.
If I were to go lower, I don't want it "slammed", maybe just a 1" drop. I don't want to lose any handling or ride comfort.
BMR, Hotchkiss, Eibach, Detroit Speed, & probably a dozen or more that I haven't mentioned.
Open to all recommendations!
Gstick is offline   Reply With Quote
Old 10-17-2022, 07:00 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have the BMR 1.25" drop springs with the B6s and they are a good match.
Old 10-17-2022, 08:47 PM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I have the Hotckis springs and really like them, I plan to match them with the B6 at some point.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-21-2022, 02:36 AM   #4
Fanch1LE
Fanch1LE's Avatar
Drives: 2015 1SS 1LE
I'm happy with my BMR 1" drop springs and Bilstein B6.
Fanch1LE is offline   Reply With Quote
Old 10-21-2022, 08:28 AM   #5
Joe.G
Joe.G's Avatar
Nice stance, Not a fan of to much gap or to low.
Old 10-23-2022, 01:18 AM   #6
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
BMR
Im 1.4” BMR with stock 1LE shocks for now.
I got the track spec so they are stiff. Which i love.
shu92870 is offline   Reply With Quote
Old 10-31-2022, 01:36 PM   #7
Maxum21
Drives: 2013 Camaro RS/SS2 1LE
I have the B6's (the last strut just arrived from backorder for almost a year) the BMR springs (1" drop). My mechanic said I should replace the Spring seats while I have it apart. Anybody have any info on good aftermarket ones, or at least the GM part numbers? It has been confusing trying to order on-line. I don't have it apart yet, so I don't know for sure what they look like exactly, Thanks for the help.
2013 RS/SS2 1LE
Totally Stock (until now)
57,000 miles
Maxum21 is offline   Reply With Quote
Old 10-31-2022, 04:03 PM   #8
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
2013 RS/SS2 1LE
57,000 miles
What tires do you have?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 10-31-2022, 06:32 PM   #9
Maxum21
In the Picture you are seeing some BFG's I bought when I lost two tires while out of state and these were the only ones available for 3 days. My Michelins were about halfway gone so I replaced all four.
They ride pretty nice and I haven't been pushing the car (900 miles in the last year) just logging tons of miles on my old truck in Houston Traffic
Old 10-31-2022, 07:12 PM   #10
George-CZ
George-CZ's Avatar
I meant dimensions
Old 10-31-2022, 11:03 PM   #11
Maxum21
Stock 285s - read that one wrong!
