![]() Join Date: Oct 2022
What is this?
I recently purchased a 2012 45th Anniversary edition with a L99/Automatic. It has a small box plugged in between the MAP and the block and I have no idea what it is.
![]() ![]() Any ideas? Sent from my iPad using Tapatalk |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
What does the label say? It's almost readable in the 1st picture.
#3 | |
I cant make it out. There is “caution”, xxxxxx Performance, “Do Not Open”. The sticker is so worn I can’t make it out. There are no knobs or anything on the outside of the box. Sent from my iPad using Tapatalk |
My guess is a "MAP enhancer" of some sort that is being used to force the car to run leaner to improve gas mileage. However, I never found any images on one that is a simple black box. Look up "MAP Sensor Enhancer". I didn't know that there was such a thing.
Is that a website name under your thumb in the first picture? |
Sadly no. No website or name I can make out.
#6 |
![]() Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
the map sensor plugs in/connected to this?
#7 |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
It looks like one of those fuel economy enhancers. I would unplug it and throw it in the trash.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
#8 |
#9 |
wondering if your car had a turbo on it before you got it?
#10 |
What is this?
I don’t know. It doesn’t look like there’s been much done to it other than a flow master exhaust and this little box. No CAI or any of the obvious mods everyone does. Sent from my iPhone using Tapatalk Last edited by catmouth; 10-22-2022 at 10:37 PM. |
#11 |
I popped the case open this weekend and took a look inside.
![]() Just a little chip with lots of goop to keep it from rattling around. Also, it looks like the two wires that come out of it are actually spliced into the bundle that comes from the MAP and not in line with that cable. Sent from my iPhone using Tapatalk |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '11 2SS, '11 C6 GS, '04 MDX Join Date: Feb 2012
Looks like it's snake oil to me. I'd take it off and test drive. If no changes then dump it.
#13 |
![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Mayby cheating maf frequency ?
#14 |
there was a map mod peeps did a decade ago but for turbos, a zener diode lowers the map signal just enough that it doesn't go into limp mode so your engine gives you more boost...sounds like that's what you got.
