Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 10-25-2022, 01:47 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Led Tail Lights MOR-1009 for 2014-2015 Chevrolet Camaro
The 5th Gen Camaro looks great from the factory but it can always be improved. These taillights will give the rear of your 2014-2015 Camaro a look similar to the 2016-2018 6th Gen Camaro.
No doubt the Camaro is a capable car, and if you've already upped the ante by making more power, new wheels, and fatter tires, then it's time for a tail light facelift too. Morimoto's unbeatable XB LED fog lights have been top sellers in our catalog forever, and we couldn't be more excited to see the lineup expand with offerings such as the new high-performance XB Camaro LED tail lights too!
COMPATIBLE: With all 2014-2015 Camaro's, these complete tail light assemblies will swap directly in place of the original Camaro tail lights, use all of the stock mounting points, and should only take around 30 minutes to install.
PLUG N PLAY: Wiring is easy too! The XB LED tails are designed to work without any special wiring. They will plug into the factory connectors for the stock lights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug-n-play install. No additional resistors, modules, etc needed!
STYLE: Inspired by the OE setup on the 2016-2018 Camaro, these are easily the best way to update the look on your car. They won't look out of place like most cheesy aftermarket replicas and match the fit and finish of OEM parts. The XB LED tails for your Camaro are available with either a smoked or red lens. Both will illuminate red.
WELL-BUILT: Their durable polycarbonate lens will resist the test of time, keeping the housings looking new for many years to come. The injection-molded ABS housing is light-weight and much stronger than comparable cheap alternatives. The XB Tail lights may not be the cheapest new tail lights for your Camaro, but they're OE quality, and as the saying goes, you pay for what you get. Although the tails are new, we've sold many thousands of the XB Fog lights and to date, have only seen a small handful with problems...no joke.
Fitment: 2014, 2015 Chevrolet Camaro
RPIDon is offline   Reply With Quote
Old 01-24-2023, 02:57 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...d-tail-lights/
