Old 10-26-2022, 11:15 PM   #1
Pekk139
Pekk139's Avatar
Drives: 2014 Chevrolet Camaro SS
N/A cam with Turbo
I’ve got a BTR stage 3 N/A cam and I’m installing a Huronspeed single T4 kit with a comp turbo 7880 .96 billet oil less turbo and was wondering if you think it’s ok to run for now until sometime next year (today 26OCT2022 to JUN2023)?
2014 Camaro SS LS3 M6
Pekk139 is offline   Reply With Quote
Old 10-27-2022, 08:59 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Personally I think that's too much cam for a turbo setup, I'm running a stage 2 turbo cam from tsp 227/239 spec'd by Jon at Huron Speed. Ran this cam on my twin kit from Huron and now my Hellion kit, idle is great and perfect drive-ability. Again its your ride so do what you think is best, if it were me I would contact Jon at Huron and see what he thinks for a single setup. Do it once.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 10-27-2022, 10:45 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Downside to running an NA cam would be the short LSA and resulting overlap, but there are guys that do it. The LSA on my cam is 122 because it's made for a turbo. I think the BTR stage 3 LSA is closer to 112 with a fair amount of overlap.
Old 10-27-2022, 03:51 PM   #4
RupertPupkin
Drives: 2014 Camaro SS 1Le
https://youtu.be/SzXjw3Png3E
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 10-28-2022, 10:53 AM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
You can make a ton of power with a turbo and any cam. If you are trying to squeak out every bit of power, then swap the cam.
If you like the way it drives and the powerband it currently has, slap the turbo on and full send.
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 10-28-2022, 04:05 PM   #6
stevieturbo
Drives: it changes
Originally Posted by RupertPupkin View Post
Also...
stevieturbo is offline   Reply With Quote
