Old 10-27-2022, 09:52 PM   #1
jason78
Drives: 2013 ZL1 Convertible
Cool LSA Intercooler Cover Rear Bolt Removal
Ok, so I went to removing the intercooler cover tonight and was feeling like the man after I got the 4 rear bolts out, Then I discovered 2 more that make the other look like cake.
So I'm really not interested in drilling out the cowling as I have see some do. I'm hoping the experts can point me to an attachment or tool of some kind that will help make this a little easier. I had someone recommend a Matco A4UB which looks promising, just hoping someone in a performance shop or who deals with these all the time can share some wise tips or other ideas. Thanks
jason78 is offline   Reply With Quote
Old 10-27-2022, 10:08 PM   #2
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
You can bend the cowling upward alittle to get to those rear bolts , and using long extension and swivel -or drop the cradle down alittle .. taking off is the easy part ,it’s getting them torqued back down will be the hard part .. My OCD kicks in and have to hit the torque rating for them bolts
I’ve seen hand wrench with a swivel joint on it being used once , but that might be hard to find ..
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
Old 10-29-2022, 02:35 PM   #3
gbu27
Drives: 2013 ZL1
The factory manual has you drop the rear of the front subframe / engine mounting an inch or so for clearance. It’s real fun…
gbu27 is offline   Reply With Quote
Old 10-29-2022, 04:09 PM   #4
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Set the car on jack stands on the front 2 punch weld jack points. That allows the front subframe to actually drop down as specified. I do this on a lift and it’s much easier than on the ground. It still is not fun to get to the rear bolts but it make it possible. I did not want to cut or bend my cowling.
SIM GhostrdrZ is offline   Reply With Quote
Old 10-29-2022, 08:00 PM   #5
jason78
Sounds like it! I don't have a lift or the confidence level to do that.
Thanks! I'll give that a shot. I almost have access from the top rear now, if I could only get a 1/2" or so that would make a huge difference. I've ordered a couple more socket and extension gizmos that should be here next week. I really don't want to cut or drill the cowling.
Old 10-29-2022, 08:18 PM   #6
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Stop making it hard on yourself. Drill the cowl. I can get the lid off in 5 minutes now.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 10-30-2022, 07:40 PM   #7
gbu27
Drives: 2013 ZL1
Yea I shoulda said… I cut spots out, it’s just easier, and no one will ever see it because it’s under the plastic you take off
Old 10-30-2022, 08:17 PM   #8
tartagliazl1
I drilled holes above each bolt. Then put body plugs in the holes.
Old 10-30-2022, 08:44 PM   #9
jason78
Trying to keep that as a last resort. Im very close to having them. At this point its a challenge and I've already ordered some tools so I may as well give those a shot.
Old 10-31-2022, 11:53 AM   #10
bstromback2002
bstromback2002's Avatar
Drives: 2010 camaro ss
I believe I did the reach around with a gear wrench when I did mine or maybe a 1/4 ratchet and a socket.
bstromback2002 is offline   Reply With Quote
Old 10-31-2022, 09:40 PM   #11
roh
Drives: 2013 ZL1
The 1st one I did, I drilled the cowl but I didn't like what it did to the cowl insulation when the hole saw exited thru the backside.
The 2nd one I did, I loosened the subframe bolts & couldn't believe how much easier it was with just a little extra room over the top.
I have a lift so it was easy for me, but if I didn't I think I would still drop the subframe if the car was nice.
roh is offline   Reply With Quote
Old 11-01-2022, 12:10 PM   #12
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
When I had my SC replaced under warranty it was 2hr. 40 min. from the time I dropped off the car at the dealer 'till the tech called and said the install was finished. No holes drilled!
Under Hood - Painted strut bar ends w/custom Polished Stainless mounting hardware, E2 CC, RotoFab CAI, ZL1 underhood decal, Amsoil oil, Black billet strut covers, Metco pulleys, intercooler reservoir, JRE 75 RWHP package.
Chassis - Hawk ceramic brake pads, ZL1 wheel decals, Amsoil fluids
Interior - A pillar gauge pod w/Aeroforce Interceptor gauges, Polished ZL1 speaker rings, ZL1 mats and console lid, Custom GPS mount
Exterior - 3M clear bra, LED driving lights, PIAA Plasma Ion yellow fog lights, Window tint, CF bowties, Technostalgia sequential tail lights
1MtnGoat is offline   Reply With Quote
Old 11-01-2022, 04:55 PM   #13
ZL1_Chris
ZL1_Chris
Drives: 2015 ZL1 Camaro
Agreed drill holes
ZL1_Chris is offline   Reply With Quote
Old 11-01-2022, 06:39 PM   #14
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The tech bulletin says to drop the subframe one inch in front, end of bolt in the back. You can be done in under and hour and a half. My supercharger was also replaced in under 2 hours.
ZMEnow is offline   Reply With Quote
