![]() Drives: 2010 Chevrolet Camaro 1SS/RS Join Date: Dec 2021
Milky Sludge inside of Oil Catch Can and small amount under Oil Cap
I have a milky sludge build up and it's pretty heavy. Should I be worried? I looked at other threads with the same title and it does not look like my situation at all. Any tips guys? There were small little traces too under the oil cap but didn't look worrysome. Also checked the oil dip stick and its just fresh slick oil every time at the bottom.
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Its condensation.
Do you take a lot of short trips? The engine not getting up to proper temp and getting a good long run will cause this.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
And how long did that take to build up like that?
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
You running E85?
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#5 | |
It was about 800 miles across 3 weeks, had 1 trip about 300 miles. No, just on 93 Premium. |
#6 |
![]() Drives: 2014 Camaro 1LT Join Date: Aug 2019
Man, I've never seen anything remotely like that in my catch can. Been running one for a few years now (about 20k miles), and the only thing I ever see is a dark oily substance.
#7 |
#8 |
The multiple very short trips are very tough on the oil (especially in a humid climate), but still seems excessive to me.
#9 |
It don’t come easy.
That much oil after 800 miles seems like the intake valley baffle issue.
#10 |
This is typical of running E85; perhaps even if running E10 with regular pump gas. My catch can lines junk up with this tan baby poo stuff. Tough to clean and I've found brake cleaner to work best. I've noticed the colder the weather is, the more it accumulates. No so bad during the Summer months.
#11 |
Alright, well I am in SE Louisiana with 20W50 VR1 oil which is a heavier oil. And the climate is starting to become cooler so that may be why. I was recommended 20W50 from my engine builder but was searching around to see if I could potentially use 15W40 or possibly even 10W40. But yes, it definitely seems excessive. I recently saw that my PCV on the passenger valve cover was plugged and the intake hole was also covered. So I will have to buy a rubber hose with a fitting to see if it fixes anything.
#12 |
What do you mean by that? I did notice today that the PCV on the passenger side valve cover was plugged and the intake hole was covered. I ordered a new rubber hose and fitting to reintroduce it. I am not aware if it will change or affect anything.
#13 | |
It don’t come easy.
Excess oil in the pcv system
#14 |
![]() Drives: 2010 1SS (6.2L - 6 spd) Join Date: Feb 2023
Does the 2010 SS (6.2) have a catch can? Where is it located?
