Old 11-14-2022, 05:41 AM   #1
docwra
Drives: 2015 Z28
Z28 temp gauge gone mad after trackday
Hi guys
I'm on a Zandvoort trackday at the moment in my z28, car has been great all morning but just got back in it to go for lunch after letting it cool down for 20 mins and the temp guage has gone straight into the red after 2 minutes of normal driving.
Radiator is cool, pipes going to it are warm but not massively hot and everything else is as normal.
My best guess is the temp sensor but could waterpump have failed? Any other ideas? I've got a couple of hours to drive home, is it worth risking it?
Should also add that it got a bit unhappy after a top speed run yesterday throwing intermittent engine light but has been absolutely fine today until now.
Thanks in advance etc, why does this have to happen in a foreign country though? 🙄
docwra is offline   Reply With Quote
Old 11-14-2022, 06:20 AM   #2
FASTFATBOY
Drives: 2013 ZL1
Check coolant level
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 11-14-2022, 10:06 AM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
It's possible the wire for the coolant sensor is grounding out or the sensor is bad. What was the reading on the DIC? What was the oil temp? Any codes from the CEL the day before? If the water pump failed you'd know it as the coolant would have quickly boiled over. If I recall correctly your car is a highly modified track car. You may want to consider getting a good trailer and truck with a few support tools and parts and also have a knowledgeable friend with you during track events.
ariZona28 is offline   Reply With Quote
Old 11-14-2022, 10:24 AM   #4
docwra
Drives: 2015 Z28
Looks like it was airlocked, let it cool down and ran it up to temp with the rad cap and expansion tank off and it was fine ..... until I started to go home, then it did it again
My guess is the rad cap isn't up to heavy track use, must be getting air in from somewhere ��
Old 11-15-2022, 03:47 AM   #5
docwra
Drives: 2015 Z28
We dont see a lot of LS7s in our part of the word so I thought Id ask the knowledgeable people here in case there was a known issue.
Thanks for the advice but I was with plenty of friends and a couple of race teams, Ive only been doing trackdays for 25 years - this particular trip included Spa, Nurburgring and Zandvoort.
And FWIW if youre going to trailer the car whats the point in keeping it street legal, you might as well take a racecar on slicks, no?
Old 11-15-2022, 05:48 AM   #6
Z/28Dan
Z/28Dan's Avatar
Drives: 2023 1SS 1LE Vivid Orange
Is your thermostat stuck? That is easy to replace if you can find one in the UK.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 03-12-2024, 09:17 AM   #7
docwra
Drives: 2015 Z28
Probably time for an update ...... strap in, its been an exciting ride.
Got the car back home after the trackdays put it onto an OBD and saw various codes related to breathing and the evap system.
Went through all of the pipes/hoses and found that one was pretty severely kinked, straightened it out and all seemed to be well again. Took it out a couple of times and then put it away for winter.
I didnt drive the car again for a few months, but within 20 minutes it overheated to the point of blowing its head gasket.
I sent it to the best LS guy in the UK https://dynotorque.co.uk/ and although he was puzzled that the HG had gone - in his words "LS7's dont do head gaskets" - he found it had breached, he also found a piston had cracked.
He also discovered one of the aftermarket sports cats had detached itself and was partially blocking the exhaust, quite likely what caused the problem as it broke while I was doing around 170mph on a German Autobahn.
All fixed, no worries, I still remember him saying "you were lucky it didnt crack the block" when I collected it
Drove it carefully for a week and then let loose ....... and it overheated again.
Back on the recovery truck, back up to Birmingham and you guessed it, the block was cracked.
Fast forward 3 months, add another head gasket, another set of bearings, a replaced cylinder liner, a much lighter wallet and about a week more of sub 4K running in to go and my main takeaway is:
If youve got aftermarket cats fitted keep an eye on them.
The guys that did the machining was also 100% that the existing liners were not standard, anyone heard of this before?
Old 03-12-2024, 11:59 AM   #8
aris
Drives: Z/28
I also blew up some aftermarket cats after a few track events!
I was lucky to discover it before anything serious could happen, but both mufflers were completely clogged with cat material.
aris is offline   Reply With Quote
Old 03-12-2024, 12:24 PM   #9
docwra
Drives: 2015 Z28
Mine was literally wedged up against the lambada sensor otherwise it would have fallen out (probably better TBH):
Bonus pic of cracked piston too:
Old 03-12-2024, 01:12 PM   #10
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Care to let us know the brand? For what high flow cats cost these days thats unacceptable.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-12-2024, 01:34 PM   #11
aris
Drives: Z/28
Mine came with my ARH long tubes. But I actually don't think it's uncommon for cats to get blown out after heavy track use. I'm not sure they are intended to run at high temps for prolonged periods.
I decided to hollow them out and run catless rather than trying another set of cats.
Old 03-12-2024, 01:51 PM   #12
NoDakZ/28
NoDakZ/28's Avatar
I was afraid you'd say ARH ha, I just purchased their short system. Although we don't do much track day events I do autox and the occasional trip to Mexico. Thanks for the info!
2014 1LE - Sold
Old 03-13-2024, 02:35 AM   #13
docwra
Drives: 2015 Z28
I dont know the brand, they were part of the Redline phase 3 package: https://www.redline-motorsports.net/...maro-packages/
Yeah, from speaking to people more knowledgeable than me it seems this is the case, if youre on track and cats arent OE youre better off without them.
My concern is that its going to be louder, it was close to noise limits here already, I guess theres only one way to find out ........
Old 03-13-2024, 10:46 AM   #14
highrevving
highrevving's Avatar
Drives: Z/28
Wait a minute....trip to Mexico?
highrevving is offline   Reply With Quote
