Old 11-14-2022, 07:09 PM   #1
ChuckZL1
Drives: Chevy Camaro ZL-1
Z28 Wheels and Tires on 2013 ZL1
Just picked up a Mint set of OEM Z28 wheels and tires 19 inches. Tires are P zero Trofeo-R. 305/30/19. Thinking of putting them on my 2013 Zl1. Any potential issues I may run into?
ChuckZL1 is offline   Reply With Quote
Old 11-14-2022, 09:59 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
19’s
Running 6th Gen ZLE on my 2010 305’s front and 325’s in the rear on 19x11 an 12’s think I need a 3mm spacer for the rear just to give me a little breathing but nothing rubs except for the parking brake cable need to tie it back possibly.
Orange Krush II
Old 11-15-2022, 02:21 AM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
You might get tired of people coming up to you and telling you how bad ass your car looks. Good score!
ariZona28 is offline   Reply With Quote
Old 11-16-2022, 01:09 AM   #4
White_Camaro
White_Camaro's Avatar
Drives: 427 SS & ZLE
I don't have a zl1 but I have been running the oem 5th gen Z/28 wheels on my
ss for years.
White_Camaro is offline   Reply With Quote
Old 11-16-2022, 08:08 AM   #5
Scotty D
Drives: 2014 1le 1SS CRMT
Hey my friend, did you need spacers for the rear and how much do you think they stick out if at all ?thank you
Scotty D is offline   Reply With Quote
Old 11-16-2022, 04:51 PM   #6
ChuckZL1
ss for years.
So Sweet!!!! Did you need to lower your car?
Old 11-16-2022, 11:33 PM   #7
White_Camaro
Its lowered on coil overs. I did have to run a camber plate setup in the front though to accommodate 305s.
Old 11-19-2022, 10:31 AM   #8
Brutale arancia
Brutale arancia's Avatar
Drives: 2013 ZL1 Camaro
ss for years.
Great pic. Brings back a flood of memories.
Brutale arancia is offline   Reply With Quote
Old 11-22-2022, 01:14 PM   #9
dennyhdaz
Drives: 2013 chevy camaro ZL1
Tires
It appears Goodyear has discontinued the Eagle F1 for my 2013 ZL1. Any suggestions for replacements? Traction is key, not mileage. Thanks!
dennyhdaz is offline   Reply With Quote
Old 11-23-2022, 02:29 PM   #10
ChuckZL1
Can't go wrong with Michelin PS4s. Have them on my stock ZL1 rims and they are great. Much better traction then the BFG.
Old 12-11-2022, 09:05 PM   #11
yellow69z28rs
Drives: 2013 ZL1 Convertible Black
Send a message via AIM to yellow69z28rs
I also run them on a 13 for years, car sits low enough to rub headers hard. They stick out a little too. I put the Z28 flares too to compensate for this, car looks bad ass even with 20s too.
JRE 750 HP package
Rag Top Rob
yellow69z28rs is offline   Reply With Quote
