Old 11-17-2022, 10:12 AM   #1
Nenous
Drives: 2011 V6 Camaro,1997 Honda Odyssey
Valve stem cleaning.
I have a 2011 RS Camaro and i have been debating if i should either drip the valve stems or walnut shell clean them.
Has anybody done both? Is there and risk to my engine?
Nenous is offline   Reply With Quote
Old 11-17-2022, 11:34 AM   #2
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
The correct way to decarbon your valves is outlined in GM service bulletin 16-NA-383. It works beautifully! The old school way from back in the early 90's was the walnut shell method but it requires a lot more work in dis assembly.
NOT A 45 is offline   Reply With Quote
Old 11-17-2022, 12:47 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I thought we were talking tire valve stems here.. lol.
Old 11-17-2022, 01:06 PM   #4
xstuntman
Drives: 2012 Victory Red LFX
Yep, at first I thought it was someone more OCD than me.
I do the spray cleaning before every oil change. I currently use CRC valve cleaner and I think it works better than Seafoam.
Suddenly got the urge to go clean my tire valve stems now.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 11-17-2022, 01:16 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
LOL, yeppers... I do clean my tire stems every time I do the wheels and tires!! Never done my "engines valves"..
Old 11-17-2022, 01:32 PM   #6
myold88
myold88's Avatar
Same here. I thought we were running out of topics on camaro5. lol
Old 11-17-2022, 02:06 PM   #7
BAD DAB
BAD DAB's Avatar
........got me too
Old 11-17-2022, 03:43 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I too thought we were talking about tire valve stems
Old 11-17-2022, 04:20 PM   #9
LS1Formulation
Drives: '13 Camaro SS '98 Firebird Formula
Good, I wasn't the only one, lol.
LS1Formulation is offline   Reply With Quote
Old 11-17-2022, 04:54 PM   #10
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
1st post for you. 👍 How many miles? Are you having issues? Hard starting? I use CRC GDI cleaner on a 3.6 LFX Equinox. The LFX replaced the LLT in the 2012 Camaro, very similiar engines. The LFX was an improved LLT, sort of. I clean the throttle body. Then use a vacuum port to spray into the intake while running. Just seal off around the port to keep the vehicle running more easily. You can also insert the spray tube at the throttle body boot. If you do not know where I'm talking about, stay downstream from the MAF or sensors. Do it a 100-200 miles before the oil change and follow the directions on the can. I do it about every ~7000 miles. I'm pulling the intake off in the spring. Will determine how effective CRC has been.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 11-17-2022, 07:34 PM   #11
chevyz1
Wife named it "Ghost"
chevyz1's Avatar
Drives: 2012 Camaro Summit White 2SS/RS M6
I was thinking the same. Thought there might be something special that came up to clean my tire valve stems.
2012 2SS/RS Camaro M6 Summit White
chevyz1 is offline   Reply With Quote
Old 11-18-2022, 10:54 AM   #12
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
For those doing this, what machine did you choose to handle the job? Happy with it?
Wondering if it will work on my Cadi CTS VSport or my wife's Grand Cherokee once it has enough miles on it.
SS_Dave is offline   Reply With Quote
Old 11-18-2022, 02:16 PM   #13
redcoats1976
i have 78,000 miles on my 2015 RS.it hasnt used much oil in that time,i think i-2 quarts in all 78,000 miles combined and is running just fine.would i be better off to leave it alone?
Old 11-18-2022, 02:18 PM   #14
xstuntman
No machine, the CRC comes in a spray can.
And if those engines are DI it should work well, just follow the directions.
