Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Fresh Dyno
Just got my first dyno run today. 585 rwhp! See mods below. Could have hit 600 if we would have tuned it to max, but this is my DD and I told him to keep my tune safe. This is my DD 585 rwhp, I did all of the work myself. Nothing blew up! Pretty damn proud.
Of course, I see I am only 15 hp away from 600 so naturally I want to do something new. Cam? TB and port the snout? Drive assembly with smaller upper pulley and bigger harmonic balancer? Who knows? He is emailing my results, I will post tomorrow.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
![]() Drives: 2013 ZL1 Join Date: Nov 2018
You won't get 15 rwhp from a more aggressive tune.
What upper pulley is on it? What air intake is on it? What cam is in it? My ZL1 makes 600wheel with a clean filter and cool air with just a 2.4 upper pulley, ported stock throttle body(VMax), K&N intake, no cats, injectors and a tune. Putting in a LS9 cam would do it and still drive like stock with zero spring/rocker arm issues.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
#3 | |
Valkyrie14
My reluctance with porting the snout is the wait. If I did that I would likely send the blower to Kong to have the whole thing ported. This is my daily, so the wait is a problem. He told me his dyno is a “mustang” (not Ford related), he said that a dyno jet measures 10-15 hp higher than his usually. So on a dyno jet I may have gone over 600. Hard to say. Either upgrade (or both?!?) would easily put me in the 600s.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If you have enough injector, and fuel pump, just throw a 2.55 on there. I just did a 2.38 (with a ctsv lower) and see about 16 psi. It made 620/650 through an auto on E85 with 22.5 degrees timing. And I have the V lid, which is supposed to be worse than the Z
How much boost are you seeing?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
Nice results, especially if you still need to pass emissions.
#6 | |
#7 | |
Valkyrie14
#8 |
Valkyrie14
Thanks! Here in Wisconsin no emissions checks to worry about.
#9 | |
Put a Gates RPM belt on it. If it is a stock style ZL1 setup in no way should it slip with stock pullies.
#10 |
Valkyrie14
I have an LS3 engine, so my ZL1 crank runs two belts not three (AC and serpentine). I have a LSX kit that uses spacers to put the single belt in line with the blower and crank pulleys. It is a six rib setup. It looks like my choices are to modify where my alternator and AC are and go to a full ZL1 setup. Or find 8 rib pulleys to go with my current setup. Innovators West makes 8 rib pulleys, I’m just not sure that is all I will have to do. The water pump is still a 6 rib width. I use a gates micro v belt.
#11 | |
#12 |
Valkyrie14
Here is the dyno report. Numbers were actually a little higher than what he told me.
Now, cam, pulleys, port snout and bigger TB, or suspension. Nothing wrong, so no immediate fixes needed. Don’t know which one to do. Pulleys probably easiest. If I did a cam doing the pulleys at the same time makes sense, but there are budget constraints. Porting is easy too, but have to send it off and this is my DD. Suspension might be the smart move, but I am concerned the upgrade will leave the ride stiff. What would you do?
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
What is your goal/use for the car? If curves are involved, suspension upgrades.
#14 |
![]() Drives: 2010 1SS LS3 Join Date: Aug 2019
Very nice on 8 psi. Shoot for the 12 psi range on E85.
2010 CGM 1SS
408/4L80E/ZL1 Vortech V-13 94C |
