12-04-2022, 08:39 PM | #1 |
Drives: 2010 2LT/RS Join Date: Mar 2015
Roof drip molding clips
Does anyone know what adhesive to use for these clips? I’m replacing mine and they are metal clips with a white backing. There is nothing to peel to expose any adhesive. These are OEM I ordered from GM.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
12-04-2022, 08:53 PM | #2 |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
Do you have a body shop in your town maybe one on the smaller size owner operator that you could ask in person for a recommendation, i would think they would be willing to give you that info bring the part and a brief background on what your doing.
You would want to use the correct adhesive so not to have to do it over and maybe the strip come off on the highway. I will be doing mine over winter hibernation and hope the clip/s don't break off. Are you painting them or putting on the wrap material? Best of luck.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
12-04-2022, 09:32 PM | #3 |
Drives: ABM #93 Join Date: Oct 2018
I would use panel bond…
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
12-05-2022, 06:39 PM | #4 | |
I have carbon fiber I will use to wrap them with. If it doesnt turn out well then I will paint them myself. Sent from my iPhone using Tapatalk
2010 2LT/RS
12-05-2022, 06:40 PM | #5 |
That would be overkill I believe. Plus it takes 24 hours to dry. If I needed to replace the clips down the road it would be a nightmare to remove/clean up the left over adhesive. Sent from my iPhone using Tapatalk
2010 2LT/RS
12-05-2022, 07:04 PM | #6 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I would think 3m vhb double sided tape would be sufficient for that. They do not catch much wind due to the design and placement.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
12-06-2022, 06:18 AM | #7 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Where's Billy Mays when you need him? lol.........I agree with Blue, or maybe a fast setting epoxy. 2 sided tape definitely not.
12-06-2022, 06:42 AM | #8 |
Been on mine for 5 years with no problems.
12-06-2022, 02:57 PM | #9 | |
I agree with Camaro2ss2010 The factory clips were held in place with doublesided tape. Sent from my iPhone using Tapatalk
2010 2LT/RS
12-06-2022, 03:40 PM | #10 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Maybe just a few self tappers and some duct tape would do it
UPSTATE C5 MEMBER
12-06-2022, 06:32 PM | #11 |
Maybe not Ha!
2010 2LT/RS
12-07-2022, 07:33 AM | #12 | |
Roof Panel Molding Retainer Procedure Ensure that a new pre-cured roof panel molding retainer is being used and discard old retainer. Apply 3M DURAMIX Super-Fast Adhesive 4747 or equivalent to the cured structural bonding on the new roof panel molding retainer. The front roof panel molding retainer is placed 25 mm from the front edge of the window frame, centered side to side in the ditch channel and secured with masking tape. Apply an overlapping drop of adhesive on the front and rear edge of the roof panel molding retainer to the ditch channel. Allow time for sufficient bonding strength. Minimum 15 minutes at 23°C (73°F) Minimum 30 minutes at 10–23°C (50–73°F) Minimum 60 minutes at 5–10°C (41–50°F) Remove the masking tape after the bonding time has elapsed. Please allow adhesive to fully cure prior to installing roof panel joint finish molding. |
12-07-2022, 08:10 AM | #13 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
It sounds like this is where some people got the confusion that white "pad" thing at the base resembles double sided tape? My question was the 'pre cured', is this pad something like two part epoxy where some correct duramix then is the second part to this pad? I know when I apply the 3m black "tape" on things it says it's activated not so much by the peeling off the red protective film tape but by the pressure pressing it firmly on. Is this correct in your knowledge? I just put a bumper protector on yesterday with it, and will put some side moldings on today that have it. I've used it quite a few times, and it does seem as if you just barely stick it on it's more likely to fall off than pushing hard on it. I guess where I get this line of thinking from also, I ordered some "activator" pads (3M 4298 Adhesion Promoter, 3 Sponge Applicators) for when using that black tape, that you pre apply. it comes in sorta an alchol wipe type package. it seems to leave something like rubber cement film on the receiving part so it sticks super firmly then ! Thanks for posting the correct procedure, I might learn something today even if I'm not doing this right now. Last edited by silversleeper; 12-07-2022 at 08:24 AM. |
12-07-2022, 08:59 AM | #14 | |
