![]() Drives: Chevrolet Camaro LS 2015 Join Date: Sep 2022
Vacuum Line Setup?
Hey guys, I know I am not on the right forum but it seems like the V6 guys are not familiar with turbo stuff so I was hoping you V8 guys could give me some help and insight. I have a Huron Speed SS Single Turbo kit and surprisingly enough everything fits except "headers" which I'm fabricating. Now, I am at the point of vacuum lines and don't know what to do. I heard about plugging it up to the brake booster, TB or intake manifold? Theres not enough information out there at least not with pictures for 5th gen lmao, What is your guys setup and what makes a vacuum line? Pictures will be highly appreciated, Thanks
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
There's a lot of words up there, but I have no idea what you're talking about.
Are you asking where to tie in your boost signal? I have a boost log (search- there's plenty of pics here for that) that supplies my BOV and Hobbs switch. That is referenced to the manifold pressure (PCV port). My boost controller and waste gate are supplied directly from the turbo housing. |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
The line from the rear of the intake manifold to the brake booster is a good line to "T" for a vacuum/boost source. Some run a vacuum block after that to split out the boost controller, BOV, FPR, solenoids, etc.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#4 | |
![]() Drives: 2015 SS Black/Black Join Date: Jun 2016
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Yes, it is - 2# (for my #2 & #3 fuel pump).
