Old 12-09-2022, 10:32 PM   #1
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
2023 Camaro 20x9.5 on 5th gen. Rubbing
So I bought these 20x9.5 all the way around and put on some 275 40s. Went to install the wheels tonight. I’ve had all kinds of 6th gen wheels on my 5th gens, but never ran into this problem.
The wheels rub against my front Brembos. Luckily, no damage to the caliper, just rub that wiped off.
Any suggestions? Spacers? Or dismount, sell these rims and start again? Likely a 3mil spacer will solve my issue.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 12-10-2022, 07:09 AM   #2
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
I think a spacer is the cheapest/easiest way to go.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 12-10-2022, 01:08 PM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Seeing you’re already brushing the caliper 3mm is cutting it too close. I would go with 5mm billet aluminum to be safe. I got mine from here , won’t be sorry https://www.motorsport-tech.com/
camguynj is offline   Reply With Quote
Old 12-10-2022, 01:30 PM   #4
LT1Zob
LT1Zob's Avatar
Thank you much. I’m looking for hub centric, these guys seem to have what I need. They’re giving me 4 options for the 2010-2022 camaro. Which one did you choose?
Old 12-10-2022, 03:24 PM   #5
camguynj
camguynj's Avatar
Design1 flat, Hub centric
Old 12-10-2022, 03:26 PM   #6
LT1Zob
LT1Zob's Avatar
Thanks. I figured after I looked at a couple.
Old 12-17-2022, 11:37 AM   #7
LT1Zob
LT1Zob's Avatar
Thank you for the 5mil recommendation. Put the wheels on last night. The front caliper clearance is tight, about 3mils, but we’ll see.
