Old 12-15-2022, 09:33 AM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
trans mount
For anyone that's either done a short shift, replaced clutch, or had any other reason for trans be out, did you replace the rubber insert in the tail shaft mount? If so did you mess with polyurethane? I'm debating the value of poly over rubber.
SS_Dave is offline   Reply With Quote
Old 12-15-2022, 10:02 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Is there a specific reason to do so for you? Gone bad or doing it for other purposes like autox/road course/aggressive street? Only reason I will be upgrading to a revshift mount is I'm putting in BMR engine mounts.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 12-15-2022, 10:04 AM   #3
SS_Dave
SS_Dave's Avatar
That's kind of the core of my question. I'll be doing an MGW and fresh clutch soon. The insert is cheap, so I was wondering about value of doing it while I'm in there. What I would get out of it. That and any caveats about undesirable effects.
Old 12-15-2022, 10:08 AM   #4
NoDakZ/28
NoDakZ/28's Avatar
I wouldn't think you'd notice too much of a difference/effect just in a trans mount. I would say if you're there and willing, change it out.
2014 1LE - Sold
Old 12-15-2022, 10:59 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I have the Revshift insert because it was cheap and I did not want to go back after I put it all back together because a mount broke. I did notice an increase in NVH, but I do have a bronze shifter cup, carbon blockers, Corvette output shaft bearing and bronze fork pads, which increase NVH a bit and I think the insert just magnified that. It did not increase NVH enough for me to ever consider taking it out.
Old 12-15-2022, 09:42 PM   #6
DavidH
DavidH's Avatar
Drives: 2010 Camaro 2SS
I went from a SS mount to Z28 factory mount. Feels very nice and minimal NVH.
DavidH is offline   Reply With Quote
Old 12-16-2022, 07:29 AM   #7
SS_Dave
SS_Dave's Avatar
They're an interchangeable fit? I'm working with a 2011 SS.
Old 12-16-2022, 09:07 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I went from a SS mount to a Z28/1LE mount an it cause NVH to the poinbt of being uncomfortable in the car, its magnified with LTH's and bigger exhaust. So im going back to my spare ZS/1LE mount an didnt notice any difference on track.
Orange Krush II
Old 12-16-2022, 09:28 AM   #9
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I have the Revshift on the shelf, I am going to install it but I want to install the Aluminum Driveshaft first, Figured if I do both at the same time I will not know which caused increased NVH . The insert is easy to install and remove from what I have read.
In my 3RD Gen Z/28 the Poly trans mount made a huge difference in shifting.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 12-16-2022, 10:23 AM   #10
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I had installed the RevShift years ago. Not sure how much more it stiffened up the movement. I got a certain, low RPM NVH (noise) that I didn't like passing through as I accelerated daily driving it. Since the 2013 and newer Camaros had a little stiffer OEM transmission mount than the earlier years, I opted to put that OEM back in. I have not encountered any detrimental effects from doing that. I do have the Prothane poly motor mounts installed.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 12-16-2022, 03:16 PM   #11
SS_Dave
SS_Dave's Avatar
Think I'm just gonna keep it simple and stay OEM.
