12-22-2022, 11:27 AM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
No Oil Pressure Warning Light
Oil pump right? What upgrades are there for oil pump, or something else that it would make sense to do if I am in there suggestions.
Also, would driving it to a shop be too much? I don’t want a seized engine.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
12-22-2022, 11:32 AM | #2 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
So it has zero pressure? Check the oil pressure sensor at the back of the valley cover. It will be behind the supercharger. If its reading zero it could be the sensor. If it was working I'd imagine you would have some pressure.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
12-22-2022, 12:06 PM | #3 |
Valkyrie14
I will check that, good point. The dash says 0.0 bars, and the gauge didn’t move.
12-22-2022, 12:11 PM | #4 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
DO NOT drive it if it’s got an oil pressure light on. Just not worth the risk.
12-22-2022, 02:27 PM | #5 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I wouldn't be even starting it unless you have a mechanical gauge installed in the place of the sensor ready to shut it off if don't see any pressure. If you don't want to test it yourself then I would have it towed to a shop. Like one said it's not worth the risk.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
12-22-2022, 02:54 PM | #6 |
Started#gottalovethatblue
If you're still driving the car with zero oil pressure, STOP! If it is a sensor then you've been extra careful for nothing. If it is a pump, you may save the engine.
12-22-2022, 09:44 PM | #7 |
Had a "check engine" light come on a few weeks ago. No other warning lights.Then noticed the oil pressure on the center gauges was flat. It was oil pump sensor that needed replaced.
12-23-2022, 04:15 AM | #8 |
Drives: 2013 ZL1 Join Date: Sep 2021
If you truly have no oil pressure your lifters will be very noisy-don't drive it. Chances are its probably just the sensor or wiring problem.
12-23-2022, 06:56 AM | #9 |
Drives: 2011 Join Date: Sep 2017
As said before oil pressure sensor.Or the screen clogged up.
When the last time the oil was change? Of motor has alot of miles try using lucas oil additive. My suburban does ithat alot |
12-23-2022, 10:38 AM | #10 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Dog bone instead of timing chain tensioner. Katech C5R timing chain. Verify oil pump is bad. If so, Melling 10296.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
12-23-2022, 12:59 PM | #11 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Whats a tow worth? a couple hundred at most.
Your engine is worth 5-7k to replace I know what my choice would be.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
12-24-2022, 12:09 PM | #12 |
ZL1_Chris
Second the dog bone issue here is a link with some good info
https://www.camaro5.com/forums/forumdisplay.php?f=11 |
12-26-2022, 09:34 AM | #13 |
Valkyrie14
I have a shop looking at it Thursday. He thinks it is the sensor. I will post an update.
12-29-2022, 09:56 AM | #14 |
Valkyrie14
It is the sensor. Problem solved.
