So Cal Chevy Invasion
Drives: 2013 Camaro 1SS/RS Join Date: Apr 2009
SC and Upgraded Intake manifold?
Im running a boosted 5th gen SS M6 and would like to know if there are any benefits of replacing my stock intake manifold? I love the look of the Holly High Rise one but dont love it enough if it will not give me much of a performance advantage for its price tag. Thanks all in advance for your guidance!
![]() ![]() Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
What blower you running ? And more importantly what cam , stock manifold is all you need up to 6200 rpm from what I've read
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
![]() Drives: Chevrolet Camaro Join Date: Oct 2022
Richard holder has done several test on this subject. The ls3 intake is really good its until you start turning 7000 plus rpm and 20 plus psi. When you may want to switch to high ram for strength and tad shorter runner. And you can run sandwich style intercooler which are nice.
Stock cam, internals etc, just bolt ons for now. Running a torqstorm SC. Going e85 with upgraded pump next. Injectors already at 100lbs.
#5 | |
#6 |
With a stock cam I wouldn't think about intake manifolds unless it was the stock rod-mod. Get a nice centri cam, you'll pick up a good amount.
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
#7 |
I appreciate the feedback. I thought about a cam first, but also know there is a price larger than the intake manifold. Makes sense though, thanks!
#8 |
Save up longer and do a cam , really your best option in your build right now
#9 | |
![]() ![]() ![]() Drives: it changes Join Date: Nov 2010
Likes of a Hi Ram or anything of that nature, would be a waste of money. Your LS3 will perform far better in the region that combo will ever be. Likes of a FAST intake would see some gains, but really you'd want to change camshaft either way. RH has done so many tests showing even fairly mild cams, yield big gains on an LS. Also doubtful E85 will yield big gains either on such a mild build. But if it's readily available, assuming not expensive, no harm in using it of course and will have a wider tuning window for whoever is tuning it |
