![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Installed cam and tuned. Idle shakes a little only with AC ON.
So I just installed a BTR centri cam in my friends car, and I tuned it. I added airflow to the usual tables and raised the target RPM. It fired right up and idled great. But it was adding 28% fuel at idle. So i knew the tune was off.
Then I disabled all fuel modifiers, like DFCF/CFCO, LTFTs, O2 sensors, COT, and added 20% to the entire MAF table. Flashed it, logged it, pulled fuel, rinse and repeat 5 times. Even without the LTFTs its spot on. So I turned everything back on, and fuel trims are within 3-4%, WOT is right on .85 (ethanol) and it runs excellent. Then we turned the AC on... and the idle got a little shakey. Doesnt stall or anything, just a noticeable difference in idle quality. I see there are 2 tables in Engine>Idle>Airflow>AC Ramp In and Out. However I dont know what they do. Has anyone modified these to iimprove idle after a camshaft install?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
I had to modify mine with my cam and cubes. I added quite a bit, nearly double what the stock values were.
This is what I added on top of the LS3 stock values so it wouldn't die or surge at idle with the AC cycling.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#3 | |
I'll report back!
So far I have tried adding those values just as you have. I've tried doubling and even tripling the stock values. Ive also tried zeroing both of those tables. (did not like zero)
I've also zero'd the torque management AC spark table that pulls timing. Best result so far is with the ramp in/out values tripled. It's not terrible or stalling, its just a slightly shakey idle. Like its had too many energy drinks. Slightly better now, but not perfect.
Have you tried mucking with your Throttle Follower Torque table since you cammed it?
#6 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The racoon is in the other tree guys.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#7 |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
seems like Ted is dropping cryptic hints guys.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
#8 |
Ok, barking up the wrong tree. Got it. I know you know how to fix it, and I also know you don't run a successful business by giving out your tuning knowledge for free. So I thank you for the course correction.
care to give a one word hint??
#9 |
VE
#10 |
