Old 01-04-2023, 03:19 PM   #1
Leonhardt
Drives: 2011 Chevy Camaro LT
2011 V6 Camaro Engine tapping sound?
I am hearing a sound that almost sounds like a tap or an airy click coming from the driver side of the engine. It's difficult to hear at low RPM such as idle (Unless it's cold started until the RPM's die down), but the moment you give the car any gas, you can hear it pretty clearly. The noise is in the video linked.
Anyone have any idea what this may be?
https://youtube.com/shorts/W1fFmHT5wf0
Leonhardt is offline   Reply With Quote
Old 01-04-2023, 06:20 PM   #2
spyderbuddy
spyderbuddy's Avatar
that kinda sounds like the Direct injection pump
its on the drivers side under the Valve Cover at the back of the engine
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
Old 01-05-2023, 08:01 AM   #3
Leonhardt
Is this an easy part to replace if you know?
Old 01-06-2023, 05:11 PM   #4
PaulsSS
Drives: 15SS Camaro
Sounds normal to me, the high pressure fuel pump make some noise. Mounted at the rear of the engine drivers side.
PaulsSS is offline   Reply With Quote
Old 01-06-2023, 05:43 PM   #5
spyderbuddy
It's sounds like that brand new, they don't go bad as far as I know. Normally they quit working is a sign the engine will not start
Old 01-08-2023, 06:25 PM   #6
Leonhardt
It never made a noise like this before, unless it's not the fuel pump that is making it? It's loud enough to hear with the hood closed and while driving past walls or other parked cars, the noise can be heard pretty loudly.
Also extremely noticable when cold started. My concern really is that it's never made this noise before until the last couple of weeks, and the car has 135k miles on it.
Old 01-08-2023, 09:01 PM   #7
PaulsSS
Drives: 15SS Camaro
Mine gets noisy then quiet back and forth for the past 140k. I just ignore it any more. It is a variable pump so I'm assuming at times depending how its being pulsed it noisy? Just a guess but its something I've noticed for a long time but stopped worrying about it when I realized it comes and goes.
