Old 01-17-2023, 08:01 AM   #1
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
M6 10.1 passes NPB
Performance Mods: upper/lower pulley, factory crank, heads, blower and shifter. Monster triple disc clutch. Fore dual pump full return, Meth, E85, PNR 5 Gallon ice tank with EMP pump. Corsa Exhaust, Rear Menscer Coil overs, BMR suspension, Hoosier Slicks & Skinnies, LT, CAM, 102 TB, Cal Hartline Tune, weight 4100 lbs
Category submitted for: Please List the Category or Category #15
R/T.............0.327
60'.............1.558
330'...........4.320
660'...........6.599
660’ mph...109.76
1000'..........8.530
1320'..........10.166
1320’ mph…137.74
Bradenton Motorsports Park 1/12/23
Weather conditions 500 DA
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 01-17-2023, 08:40 AM   #2
97ChameleonTA
97ChameleonTA's Avatar
Drives: 2013 ZL1 Convertible
WooHoo! Time to update that sig!
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15
FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's
New times to come with E85
2016 2SS Auto - Hyper Blue Metallic
Roto-Fab CAI
97ChameleonTA is offline   Reply With Quote
Old 01-17-2023, 08:53 AM   #3
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Thanks Buddy
Old 01-17-2023, 10:15 AM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Nice lick, and killer starting line shot!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 01-17-2023, 11:26 AM   #5
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Thanks Man! Yeah that shot kinda blew me away also
Old 01-17-2023, 12:39 PM   #6
acammer
acammer's Avatar
Mine's been a 1.56 in the 60', and I'd give a lot to have seen what it looks like leaving, because it sure felt like it had to be pretty close to dirty dangling those front tires for a split second. Got plans for more changes?
Old 01-17-2023, 03:22 PM   #7
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Always love seeing your post bud. Car sounds wicked.
owhite3003 is offline   Reply With Quote
Old 01-17-2023, 06:50 PM   #8
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Thanks Buddy. It was a great night. Here is the back up 10.1 pass.
Old 01-17-2023, 07:09 PM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
That's a strong sixty Man! That is where I need to be more consistent. I'll be adding front Menscer coil-overs soon which should help. That will be it for a while.
I just like to Race. Not a time-slip chaser. Every now and then you get a good slip in a 6 speed. It's not easy though.
Old 01-18-2023, 07:26 AM   #10
acammer
acammer's Avatar
That's the truth man, it's without a doubt the hard way to do things. So rewarding though. I know my struggle with getting a slip like that... I'm two tenths off the the nines, so I'll be trying to find a way to get there!
Old 01-19-2023, 04:08 PM   #11
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Dang, Chett!!! Well done. 9's, here we come, baaybeee!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 01-19-2023, 05:21 PM   #12
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Think he’s there already if he wanted to push that shift a little faster, but he is very smart not to.
ZMEnow is offline   Reply With Quote
Old 01-20-2023, 07:23 AM   #13
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Getting close Rob. It's a low 10-sec full weight M6 ZL1 for now. Will need a 1.4 sixty, great air, a tail wind, and a hot naked chic at the 1/4 mile trap blowing kisses at me for a 9
Thanks Man. You are correct. Definitely more there in the 1-2 and 2-3 shift. I like making clean passes though. Missed NLS has been done at lower HP levels with carnage.
Old 01-20-2023, 08:18 AM   #14
ZMEnow
Yep NLS was great at stock HP, but higher HP seems to excessively wear the clutch and everything else behind it. Replacing the clutch on these by yourself makes you stop it.
