Old 01-17-2023, 04:22 PM   #1
Jared_Wazz
Drives: 2015 Chevy Camaro SS Convertible
2015 Camaro SS Convertible Rear 10" Whoofer Swap (8 Speaker Boston Spk System)
Hey y'all, just sharing that I was able to re-use the OEM metal bracket to mount my new Skar Audio IX-10 D2 10" 400 Watt Max Power Dual 2 Ohm Car Subwoofer. The placement is behind rear seat, which BTW was a pain getting off until I realized that you simply push down on the tabs in the cutout holes right behind the top of the seat while pulling "out" on the seat at the same time. 2 tabs centered behind each seat. Use a short flat head.
The 8 TORX screws for the sub didn't line up perfectly so I tossed them, and bought Qty 8 (#8 3/4" sheetmetal screws) that did the job perfectly.
I also reused the wiring connector which made re-install a breeze.
Sound level is 2x better, but I'm buying a 12" powered bass pipe and using the ******** Exclusive 2010-2015 Camaro Plug & Play RCA Output T-Harness item: 5G-X3 RCA to get the extra bass I want.
PS the SS convertible has 8 stock speakers (Boston). (1) 3 1/2" Center Dash Two Way, (2) 1" Door Tweet, (2) 6.5" Door Mid Subs, (2) 3 1/2" Rear Panel Two Way, and (1) 10" Whoofer Behind Rear Seat. (NO 6x9's on convertible)
Jared_Wazz is offline   Reply With Quote
Old 01-18-2023, 01:57 PM   #2
Crazych66
Crazych66's Avatar
Drives: '12 Camaro 2SS/RS Vert
Thanks for sharing! Do you have the stock stereo?
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: LSA S/C, FIC 1000 injectors, ZL1 fuel pump, Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
Crazych66 is offline   Reply With Quote
Old 01-18-2023, 02:42 PM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Is that a free air sub? If not it won’t sound nearly as good as one designed for free air. There are a lot of holes in the metal rear seat back that would have to be completely sealed for a regular sub to sound good. Sure that will work but not to its full potential.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
