01-20-2023, 03:06 AM | #1 |
Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Electronic throttle for an air scoop?
I'm not sure where to even look for the linkage setup? I know I could always go with the conventional modern blower like LSA, Kenne Bell and Magnuson, but I want to try and fit a 6-71 or 8-71 to my LS3 (converted L99).
Is there any sort of electronic throttle for that application?
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
01-25-2023, 09:14 PM | #2 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
use a throttle body motor and parallel the electrical connection to your actual throttle body....
just need to figure out how and where to mount the motor....might be able to get away with one adjustable pivot point to get the actuation you need. |
